Results 1 to 4 of 4
    Active Member One Ring rcavenecia's Avatar
    Jan 20 2016
    Baltimore, MD
    keyless remote randomly failing
    sometimes remote opens and/or closes the car and sometimes I have to do it manually.
    some posts suggest antenna worn wires hanging by a thread thus working randomly due to car movement.
    could someone illustrate or explain were are these wires located? many thanks!
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    They're behind the passenger taillight
    Jan 20 2016
    Baltimore, MD
    Quote Originally Posted by bmos View Post
    Could anyone further explain how to reach this location? I'd like at least to identify if there is bad wiring before taking the car to the shop
    Jun 30 2008
    Erie, Pennsylvania
    My remote was intermittently working for a couple weeks then quit altogether. The problem was corrosion inside the key fob remote due to a failed PANIC button rubber. Failure (tearing) of the rubber allowed moisture and contaminants to infiltrate the internal electronics. Corrosion ate a few pins on the surface mount chips and it was not easily repairable. I replaced with a new remote from ebay. If I had caught it before it fully quit, I might have been able to clean and resolder a few things and keep it working.
    A wet lock module in the trunk or wiring/antenna fault could also explain your issue, though.
