    Jan 12 2010
    SE Pennsylvania
    Question Can't get into Hidden Menu. Help please.
    Just decided to venture into the Hidden Menu on my 2014 S4 with MMI+ 3G.
    Tried to get in by pressing at the same time and for 5-6-7 seconds, the menu and car buttons.
    Tried this with accessories only on and with all systems on but could not get to the Hidden Menu.
    Any suggestions?
    I do not have access to a VAG-COM yet.
    Also, when do we reset the MMI+...to restore original settings or to lock in any changes made?
    TIA
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    you need to code it in vagcom first before hand
    go to information electronics and do
    adaptation : development mode change value from 0 to 1
    if you don't have that changed , holding car and menu won't do jack for you
    search the vagcom on forums otherwise,you may get a new one ripped
    2018 TTRS
    Mar 21 2015
    You can use Carista to unlock the hidden menu too. There is a sticky for Vagcom.
    Mar 01 2016
    Fort Worth, TX
    You can also enable the hidden menu using the paid version of the Carista app along with an OBD2 adapter. I got the Carista branded bluetooth OBD adapter and it works great with the app on both my iPhone and iPad. I only mention this because the total cost going the Carista route is about $60. I'm sure you won't have as much capability to make changes as you can with the VAG-COM, but I was able to make the little changes I wanted (Disable wink, window control with remote, footwell lighting on while driving, etc...) without any problems.
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    here is the coding if u end up buying a VAG:
    Enable Hidden menu in MMI
    [5F - Information Electr.]
    [Adaptation - 10] -> Channel 6
    change 0 to 1
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
