Results 1 to 9 of 9
    Apr 11 2013
    San Bernardino, CA
    Unhappy A/C Line Compressor To Drier: 2 different part ### HELP HELP HELP!
    So I am driving in LA, car is lowered (not slammed, on lowering springs, but kinda low on the front), When all of the sudden a will hole appears. Cannot dodge it, and I hit it! This makes me lose my hose, goes from the Compressor to the Drier. Apparently there is two OE numbers, 8E0260707AN and 8E0260707AT. I know I need the 8E0260707AN, but can't find it cheap. The other one, 8E0260707AT, seems to be A LOT easy to find. So my question is, does it makes a difference on the hoses? Would I be able to use 8E0260707AT instead of 8E0260707AN? What is different, The pressure? both seem pretty similar.
    I would truly appreciate if someone can help me, because is really hot here and i need my A/C :( :( :(
    Apr 07 2011
    Call your dealership and run the part numbers by them. They look like the same exact part, guessing the "AT" part is a revised version of the "AN" part so both should work. The are both ridiculously priced(~$330) so I'd look for one at the junkyard honestly.
    "AN"
    "AT"
    Apr 11 2013
    San Bernardino, CA
    Thanks! I appreciate that sir! I will call the dealer and see what is up with that! I found them on ebay for a lot less than ecs tuning. I love ecs tuning, but i really dont want to spend much more money on this, as i am trying to get an B8 A4 or an A5 :D
    Established Member Two Rings Shortrun's Avatar
    Dec 21 2015
    Ontario
    We got one from ebay and it did not fit. It was bent wrong. So be carefull.
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    I got one if you need one. Msg me.
    Feb 17 2004
    Liberty Hill, TX
    just a FYI, there are different parts depending on the MY; I went to replace the line on my 02 with one from an 04, and while the compressor end fit, the other end did not. I ended up just having my mine rebuilt for $40 locally
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    Anyone know the difference between the 02 and 04 compressors?
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    Quote Originally Posted by Matt Devo View Post
    Rebuilt? Did not know that was possible. I punctured mine on a low curb. Is that kind of damage within the rebuildable spectrum?
    2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
    2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by ZipMeUpJ View Post
    I'd assume so, sounds like the kind of thing that could easily be welded. Mine was a leaky seal, they completely rebuilt the line and pressure tested it.
