Results 1 to 17 of 17
    Veteran Member Three Rings Dorny1's Avatar
    Feb 06 2010
    2010 Audi A4
    North Eastern, IA
    Got cash to burn...well some to burn (Reliability Suggestions)
    So I have a bit of cash burning a hole in my pocket. I am already stage three and the TB and waterpump have been replaced in the last 15k, all motor/trans mounts, shifter, new clutch, CA's, and other various maint. Car is over 200k mi as of the last time I drove it. I'm looking at things that I could throw on the make my "OMG this thing is going to fail on me next time I floor it" feeling. Overall the car is in pretty good shape. It makes 4 hour journeys to the other end of the state on occasion, and did a 7 hour journey through a pretty intense snow storm (Thanks Continental for the traction).
    Crap I've already ordered:
    ECS diff mount
    Stern rear diff mounts
    ECS crank pulley
    After run sensor
    Will be buying:
    1 piece driveshaft
    Rear calipers
    Rotors and pads all around
    metal clutch slave
    Some sort of Catch can setup
    What else wouldn't be a bad thing to grab up. I have a habbit of replacing OEM parts with performance parts if they will increase the reliability of the car.
    2010 Audi S4 GIAC Stage II, H&R Sport springs/Koni Yellows, USP Intake, AWE Track exhaust.
    (SOLD) 2001.5 Audi S4 Stage III
    "I love my mullet exhaust...Quiet in the front, Loud in the back"
    Jul 04 2012
    Woodbridge, VA
    How are your axle/CV joints/boots?
    Feb 06 2010
    2010 Audi A4
    North Eastern, IA
    Fronts have been replaced in the last year. I check them quite frequently after I blew one apart on a launch cause the axle bolts had come loose. (flange was replaced as well)
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Damn. Looks like you did a bunch. How about the little piece that holds the sun visor in place. Mine broke and it sucks when I get into boost and it hits me in the face.
    Sent from my SGH-M919 using Tapatalk
    Feb 06 2010
    2010 Audi A4
    North Eastern, IA
    Actually the hook is good but the visors little part that creates the friction holding it in has kind of broken off but the bar of it is still here.
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Looks like Go is covered, maybe focus on show, Bag it and new wheels S4 seats etc.
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    I have 17z or 18z Brembo calipers of you want a BBK.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    Quote Originally Posted by Austonwerner4 View Post
    bbk
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    please don't put that crank pulley on there
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    Yes, buy a 2nd vehicle lol
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
    Feb 06 2010
    2010 Audi A4
    North Eastern, IA
    Why not with the crank pulley?
    No bags for me, already on coilovers. I have a set of wheels. Go is never done :D.
    Second vehicle is in the works already.
    I've played with a BBK, but $700-$1k for just the fronts feels like alot. I don't have many tracks around my house just a drag strip...It's Iowa lots of long open roads. It might help for panic stops a bit, but I've seen that its more on the reduction of fade that makes the difference for BBK's
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by Dorny1 View Post
    He's probably referring to the lightweight crank pulley. Supposed to be bad for the engine. Throws harmonics off.
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    BBK is likely more than what's necessary. I'd just upgrade rotors and pads if brakes are something you're considering. After living in NE IA myself, id invest in a nice skid plate if you haven't already. You could always put some $ towards a set of Ohlins
    2002 Pearl/onyx S4 Avant
    Aug 06 2008
    Canadia
    Upgrade the TBB, fuel pump, replace the after run pump, coolant sensor, fan controller, repair/replace pcv assembly, valve cover gaskets, timing chain seals, replace the small power steering hose on the left of the pump on top of engine, new green check valves
    That's probably a good start for reliability, all things I've personally done too
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    Quote Originally Posted by 88ninety9 View Post
    I'd have to agree on everything but the BBK. I finally was able to upgrade the front brakes w/ a TT-RS 370mms and its a world of difference, so much safer feeling to push it on the everyday commute and be able to stop these pigs. Running stage 3 power without upgraded brakes wasn't the best idea. My next step is to upgrade the rears to match, the ECS larger rotors and Hawk 5.0 pads for now I figured would add some bite I need to the rear to balance out the upgraded fronts. And OHLINS, that'd be the icing.
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    How about the rest of your suspension? You said you've done some control arms but there's a lot more to it
    Feb 06 2010
    2010 Audi A4
    North Eastern, IA
    Quote Originally Posted by MacDaddy View Post
    Only havent done the fan controller...
    I have a skid plate, was my first upgrade. I have a rsb already as well. I'm doing all the brakes with stock rotors and Akebono or hawk pads. I also already have stainless brakelines.
