Originally Posted by
BlownOne
80/20 mix of meth/water, the Teflon coating doesn't affect anything performance/longevity wise, pre blower doesn't cool as well as directly injecting into the plenum, only inject straight water if you want a hydro locked engine, you can also get a different nozzle and inject e85 alternatively. Search sround on the ctsV forums...there's plenty of info on it.
Will
Ughhhh
You will not get a hydro locked engine from spraying 100% water if your nozzles and psi are setup properly. Unless you are managing you get 250 mls of water into the cylinder on each compression.
Also the temp sensors used by the ecu for fuel and timing calculations are in the blower housing above the intake runners (we don't have a plenum). So while a direct port solution would provide greatly lowered exhaust temps and intake temps into the cylinder, the ECU won't see the lowered temps.
Will, I understand you are trying to help but that is a lot of misinformation. About the only thing right is the 80/20 mixture which for INTAKE COOLING is a great mixture.
I have been running W/M on THIS platform for 3 years almost. I have tested every mix, and logged them all. I never hydro locked my motor.
I managed the lowest cylinder and exhaust gas temps with 100% water.
I managed lowest intake temps with 100% meth.
With all water the AFR went leaner, and with 100% methanol it went rich. I typically use 50/50 all the time. The ECU on this car is so dynamic that it can adjust to the mixture you are injecting. Once you find a mixture however, stick with it. If you change the mixture the car will act a little funky until it adapts to the new cocktail being injected into it.
Research heat of vaporization properties and understand OUR platforms needs.
