Results 1 to 6 of 6
Thread: Bad battery?
    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Bad battery?
    I'm having some issues that are leading me to believe my battery is going bad. I just took the battery to advance auto (optima red top r34) and here are the test results...
    Voltage: 12.20v
    Measured: 786cca
    Rated: 800cca
    Temp: 72 degrees f
    Recommend charging.
    Do these specs fit? Is it actually still good? Or should I replace it
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    How old is it? I've had batteries test as Good. But had very little life left.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    It's 2 years and 7 months old as of now
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    Quote Originally Posted by rtk8892 View Post
    Voltage: 12.20v
    Measured: 786cca
    Rated: 800cca
    Temp: 72 degrees f
    Recommend charging.
    Spec says anything below 12.5V is bad, was this when it was fully charged?
    Veteran Member Four Rings evildsmr's Avatar
    Sep 13 2012
    04 Imola V8, '21 Army Green Taco
    Denver
    Just go buy a new battery and put it in and if it doesn't fix your problem take the battery back.
    Sent from my Nexus 6 using Tapatalk
    Mar 21 2015
    Voltage: 12.20v
    Measured: 786cca
    Rated: 800cca
    Temp: 72 degrees f
    Recommend charging.
    I had a red top and a cell went bad. Took it back for warranty replacement and the guy told me they have red ones come back all the time. He switched me out for a yellow top.
