Results 1 to 3 of 3
    Oct 05 2015
    Idaho
    Complete 2.7t Stage 3 Setup - No Longer Available
    I am selling my stage 3 2.7t setup. The engine comes from a 2000 A6 with 80,xxx original miles. I am selling the engine and all its stage 3 components as a package, this is a great opportunity for someone to go stage 3 without having to spend extensive time piecing everything together and working on the engine. I'd like to call this a "plug and play" solution. All you'll be required to do is replace the engine, mate this setup to your transmission and you'll be good to go. Turbos have only 10,xxx miles on them and whole clutch setup and injectors were brand new 5000 miles ago. The reason for selling is I've a acquired a new B6 project and will be using the funds from this part out to fund its well overdue overhaul!
    The engine will be pulled and palleted as a whole very carefully ready to be shipped.
    Below is a list of what is included in the package and how much I paid for the parts at the time:
    APB Engine (With Harness, all pumps and ancillaries etc.)
    $2,700.00 Genuine Borg Warner K04s
    $370.00 XS Power RS4 Replica 2" Inlets
    $1,500.00 AWE intercoolers and shrouds
    $60.00 034 TBB
    $100.00 710 N Diverter Valves
    $100.00 Ceramic costed intake and exhaust manifolds
    $300.00 Bosch ev14 550cc injectors
    $270.00 034 85mm MAF housing, airbox adaptor, silicone intake hose
    $750.00 Clutchmasters stage 4 ceramic clutch (With RS4 Pressure Plate)
    $500.00 LUK OEM Flywheel
    $500.00 Custom tuned 91 Octane ECU 500hp/550ft/lbs
    $7,150.00 --- Total Spent (Not including value of the engine)
    Recent Maintenance:
    Full Engine Refresh - Winter 2015, all seals, bearings, rings, valve job, main stud kit, New Oil Pump, timing chains, oil pump chain, and all tensioners
    Timing Belt/Water Pump / Thermo / Valve Cover Gaskets / Cam Gaskets - Winter 2015)
    Polyurethane sprayed valve covers, engine covers, coolant pipes, Y-pipe
    New Front 02 Sensors - March 2013
    New Power Steering Pump April 2015
    I have included pictures and a video link of the engine running healthy on 03/18/16 no smoking, rattling, knocking etc. Also included a picture to illustrate how clean the head is when doing the recent VCG reveal. Having only circa 80,000 miles and a recent refresh the engine is in spectacular condition. https://youtu.be/tMjyEtOwtf4
    Feel free to PM or preferably text/call 208 340 8769
    List Date: 3/18/2016
    For more info, click here to view the original listing: Complete 2.7t Stage 3 Setup
    This item is no longer available.
    Dec 06 2015
    Miami
    might be interested in engine if buyer just wants stage 3 parts and if seller is willing to part...free bump
    Oct 05 2015
    Idaho
    Quote Originally Posted by S4KARL View Post
    Text me at 208 340 8769
