Results 1 to 17 of 17
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    Has anyone removed their exhaust tips?
    Just wondering if anyone has removed the exhaust tips on the 2015 S3. I took a look under the car last weekend, and while there is a clip you can see from the back, I can't tell if it's actually doing much to hold the tips on. However, after some tugging/twisting, they wouldn't budge.
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    That would be great to know, was going to go cheap and paint mine black, but don't want to pull the exhaust to do it. Painting on the car is a recipe for a crap result.
    2016 Monsoon S3
    My slow build link - Onequick4door
    Oct 03 2015
    Illinois
    Quote Originally Posted by onequick4door View Post
    Got that right. I was thinking about powder coating mine. The only thing I thought that might get them off is a rubber mallet from the back side. If you tap around the perimeter enough they seem to move. I'm just not so keen on taking a hammer to my exhaust.
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    I want to powder coat black as well, I hope someone finds out. I do believe they are clipped on.
    Oct 03 2015
    Illinois
    So someone asked the same question on the S3 owners group on facebook and it appears a rubber mallet is the way to go...
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    There is a clip on the rear inside. Just press down using a flathead screwdriver and pull the tip backwards.
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    Awesome! Thanks
    2016 Monsoon S3
    Sep 13 2015
    Hell City, Az.
    it would be nice if someone sold a bolt on exhaust tip kit for the stock catback.
    I could care less about an aftermarket catback, or spending $1500 on a set..
    Oct 03 2015
    Illinois
    Quote Originally Posted by selp View Post
    +1
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Yes I need slightly bigger tips. Or even if they were rounder to close the gap to the valance on the top side.
    -cW
    Sent from my SM-G935V using Tapatalk
    2023 X3 M40i Alpine White
    Established Member Two Rings m3brad's Avatar
    Jul 22 2014
    Midwest
    Agree with coolwater!
    Senior Member Three Rings DarkSideGTI's Avatar
    Feb 05 2008
    SL,UT
    Like these?
    https://www.magnaflow.com/products?partNumber=35210
    I don't know what size the OE piping is though. You would need to measure that first. Also Dimisa and Cyba make bolt on tips as well.
    This car is running Cyba brushed tips.
    2017 Avalanche Raptor
    2015 Monsoon Grey S3
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    Quote Originally Posted by DarkSideGTI View Post
    Like these?
    Stock piping diameter is ~2.25, so that tips inlet diameter would be a tad too large. Jimmydever just did a great job with our 35123 tips:
    These ones were welded on, which is something any exhaust shop can do inexpensively. More info on his thread can be found here:
    http://www.audizine.com/forum/showth...1#post11490872
    Feb 05 2008
    SL,UT
    Do you sell a slash cut double wall 3.5" tip with 2.25" inlet? I'm not seeing it on your site.
    Jan 26 2015
    Oceanside, CA
    At this time we do not. Most of them will be 4" tips.
    Feb 05 2008
    SL,UT
    quad 4" tips is just too big for a car this small.
    Apr 27 2010
    West Chester PA
    I have been very happy with Magnaflow tips. I had their 4 inch slant cut tips on my MK6R and went right to them to see if they had tips i liked for the S3. Quality is always great and the materials hold up incredibly well. All 4 were perfectly to spec and straight and true. the stock piping is 2.25 and they are 4 inches apart on center. So if you were to put 4 inch tips on the stock pipes they would touch. 3.5 was perfect for me and is the width of the stock oval tips.
    Quote Originally Posted by MagnaFlow View Post
    2015 S3 Daytona 1 Package | Unitronic Stage 1+ ECU | Unitronic Stage 1 TCU | H&R Sport Springs | CTS Intake/ Turbo Inlet | APR Turbo Muffler Delete | OEM Resonator Delete/ Flap Mod | Welded Magnaflow Tips | 19x8.5 ET 45 Forgeline ZX3R with 245/35/19 Conti DW | 20% Tint
