Results 1 to 6 of 6
    Senior Member Two Rings audi1.8tFTW's Avatar
    Aug 04 2010
    Québec, Ste-Foy, Canada
    Rear light warning signal !!
    I just bought a new a4 (04 sedan) to replace my 02 sedan since she's dead :(.
    So the car is in great shape, but all the rear light signal are flashing when i start the car. Even if they are all working perfectly. I thought that it might be the aftermarket hid ground thing, so i did already grounded the driver light directly on the frame + located the ballast at stock location, under the headlights.
    The brake light signal + esp disapeared but the rear brake light/plate light/rear flasher's/rearfog light warning are still beeping.
    Is there anybody who experienced this issue before ? I searched on the forum and internet and could find an answer.
    Also, the car trunk look like the last owner as been bump, (bumper not even damaged but i can still see some ply on the trunk frame). He told me that it might have been the previous but he never had any other problem but the signal thing.
    Denim Blue A4 B6.................................3" custom down pipe
    Frankenturbo...........................................Organic clutch stage 3 (by clutchmaster)
    Custom aluminium airbox..........................3" double vibrant resonator
    440cc bosch injector................................Coilover ECS
    Uni stage 2+ chip, +2psi for franken.........Rs4 rear sway bar
    Aug 04 2010
    Up !! Oldguy any clue ? Hahah anyone ?
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    I believe there is a ground connection in the left side luggage compartment that those lights use. If it has been in an accident that ground may be damaged causing resistance/light out warning. I am not near my Bentley to show you the location. I am sure others will chime in. Was the rear end damage on the drivers side?
    Aug 04 2010
    Well it does look to me like it, i'll check for that one as soon as i'm done working ! That's solething i though it could be but now that i know the location i wont have to seek for it !! I'll let you know hiw it turn out
    Aug 24 2014
    Vermont
    Sorry for the crappy pic as I have the paper Bentley. Point 50 is the ground termination for the rear left brake light and license plate. Check the ground and wiring.
    Aug 04 2010
    Update:
    Wasnt the ground, everything is perfect down there, the only damaged part by the previous owner cannot affect any wire, everything look rly clean..
    Next step, i think i might have to check the wires going into the trunk and close to the lights, maybe im grounded somewhere else -_-
