Results 1 to 24 of 24
    Veteran Member Four Rings Tanzimur's Avatar
    Feb 21 2013
    97 Brilliant Black A4 B5 1.8T
    Warren, MI
    Exclamation 034 Billet Pcv Valve
    I know this topic is beaten to death but like many others when going to a bigger turbo setup we get the oem pcv valve fail on us and end up pressurizing the block even more and have oil blowing out of seals we dont like, i see that most people have a problem with dumping to ground especially if they upgraded to the spring style front and rear seals that require a small vacuum to hold those in and not seap oil, and was wondering if this billet aluminum works as great as they make it seem, especially since its not a diaphragm instead a ball and spring setup!
    May 10 2015
    Pittsburgh PA
    Unfortunately I can't be of much help on this topic, but I think you might be able to answer a question I've had for quite some time. Does the PCV system, in stock formation require vacuum to work effectively? I assume it does but wanted confirmation, as I currently dump to atmosphere (due to a broken pipe) and plan to fix it, but if it doesn't need vacuum I'd rather just leave it as is. I've searched everywhere for a more definitive answer, but how found people arguing both sides.
    Thanks
    S-Line converted | A7 356mm BBK | OEM 19x9" A8 wheels | Spec Stage 3+ Clutch | ECS LWFW | IE 3" downpipe | CTS catback | IEStage2+JB4 Stack Tuned | Meth Injection and more... +
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    I've actually heard the 034 pcv valve does not work well.
    Sent from my VS990 using Tapatalk
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
    Feb 21 2013
    Warren, MI
    Quote Originally Posted by 19birel View Post
    Thanks
    ye that is an arguable question but most dump to ground without any problem, reason it needs vacuum so to say is so the oily waste isnt ending up on the ground but instead recirc through the system for emission purposes. Thats from my understandings of what other argue.
    - - - Updated - - -
    Quote Originally Posted by B5nDisciple View Post
    ye i see some bad reveiws but thats from waaay back and since then i do see they have revised the product very well!
    Aug 23 2014
    Tucson
    Quote Originally Posted by Tanzimur View Post
    - - - Updated - - -
    Hmm, curious if anyone can chime in? I believe Metalman removed the 034 piece because it wasn't working properly (could have been someone else).
    I replaced my pcv with an oem piece just recently as I have my IM removed and I'm going through my vacuum lines and check valves.
    Feb 21 2013
    Warren, MI
    ye i ordered an oem replacement with the whole 3 way and lets just say it does not hold up to a k04 rs6 hybrid boost... thats why i ask i dont want to risk running to atmosphere and blowing out the crank seal again...
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Supposedly the current billet PCV valve should be fine. It was the older PCV valve that I had... it caused an annoying idle issue on my old AEB car, that I threw $$$ in parts at trying to resolve, until I realized the issue started after installing the 034 valve. Replaced with an OEM PCV valve and problem solved.
    About a year ago I finally returned that old PCV valve and was able to get 034 store credit.
    I run the Genuine PCV valve now. It does leak a tiny bit. I'm rather curious how good the current (revised) billet valves are, but haven't felt an urge to try one out.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Aug 23 2014
    Tucson
    Quote Originally Posted by MetalMan View Post
    Thanks for the feedback Travis!
    Curious if anyone is having good results with the new billet valve that can chime in?
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    How would running to atmosphere blow seals out?
    Feb 21 2013
    Warren, MI
    Quote Originally Posted by Davdraco1 View Post
    I dont know if it was a coincidence at the time, but before i had installed this engine i redid all the seals with he latest and greatest and supposedly the newer seals with the spring around them require a small amount of crankcase vacuum or they blow out if there isnt anyway and thats what happened one day after i tried it reinstalled pcv and re did the crank seal and all was good.
    Feb 21 2013
    Warren, MI
    I guess it could be a possibility that my pcv box to the block could be filled with crud or i need to run the billet lug instead of running a hose off the small piece that clips ino the block
    Oct 10 2013
    State College PA
    I have the 1 in 034 crank case adapter and am just dumping to the ground. Haven't blown any seals.
    Feb 21 2013
    Warren, MI
    The billet aluminum 3/4 plug right? And u blocked off the tip hole and manifold?
    Senior Member Three Rings DoesntCare's Avatar
    Feb 28 2016
    SEPA
    Here is an article about Crank Case Ventilation:
    http://www.allanglesdesign.com/porta.../CCV_Bible.pdf
    Personally I ran a recirculating catch can system with no PCV valve on my last 1.8t, and intend on doing so with this one as well.
    Aug 23 2014
    Tucson
    Anyone having good results with the revised version?
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    I am running the updated CCV kit from 034 but for AEB. No complaints or issues on my end. No leaks or drips, and it works better with the APR TIP then the stock hard line.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Orange County, CA
    Quote Originally Posted by Wrath And Tears View Post
    When was it revised? My Breather kit w/ billet PCV valve from July 2013.
    B5 Parts For Sale
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by OverSpun View Post
    I think you should have the revised one. My pre-revision one was purchased late January/early February 2012. Symptoms included fluctuating idle, at least on my old AEB.
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    I'm not sure if I have the updated version (bought the kit in 2013 but not directly from 034 so it may have been sitting around for awhile), but I haven't had any (noticeable) issues with idle anymore than normal
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Orange County, CA
    Thanks, thats good to know. How much did it fluctuate?
    B5 Parts For Sale
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    If normal idle was ~850 RPM, it would go up to ~1300 RPM on occasion, at random. Keep in mind this was DBC, and DBW may respond differently.
    Orange County, CA
    That's definitely a lot different from mine but it doesn't really bother me. It idles 800 / 840 sometimes (840 is normal with mine...). May only happen until the car is fully warm but I don't pay enough attention since it's not much.
    B5 Parts For Sale
    Feb 06 2013
    VA
    FWIW, not sure if related to the pcv or my injectors (installed both at the same time), but I idle at 1-1100 pretty much all the time. That being said, it hasn't ever affected anything and hasn't caused any other issues.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by pbcrazy View Post
    I think it's abnormal to idle that high... Your tune (same one I ran) should idle between 800-900 RPM. You can simply try pinching the line between PCV valve and intake manifold and see if that makes a difference. Can try pinching other various vacuum lines and see if anything changes.
    Also might be worth verifying that when you instrument cluster shows 1100 RPM, that the ECU is reporting the same speed (using VCDS or any generic OBDII reader).
