Results 1 to 7 of 7
    Senior Member Two Rings mousewei84's Avatar
    Dec 21 2015
    Proper Tire pressure for track day?
    Hi guys! So I just got new set of tires and wheels and ready for coming track day. It is 275/35/19 96Y Michelin PSS compare to OEM 255/35/19 96Y XL Dunlop SP SPORT MAXX GT. So OEM suggested pressures are 41/38 for full loaded car and 38/32 for normal load condition. I am wondering if the change of my tires and sizes would affect standard tire pressures? There are width change(255 to 275) and load index change( XL to nothing). Also personally i don't know if it is gonna be a problem if load index XL is gone. Currently it is 43/39
    Also I plan to track those tires, in your experience, what is the proper track tire pressure for Michelin PSS tires?
    Car is 14 S5. Thank you for you help!!
    Veteran Member Four Rings dazed1's Avatar
    Jan 18 2013
    SF Bay Area
    All depends on the track, driving style, track temp, ambient temp, how hard you push and get the temps up, etc. Too many variables.
    Start with door temps and then work your way up / down based on how tire temp + pressure change & feel.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    I had some track events with my 13' S5 with 275/30/20 Michelin PSS , normally I would set it down to 34F 33R (cold) before my first session, and release a little bit if necessary (set 40F 39R when hot) after the first session. Then it would be good for the rest of the track day.
    I would suggest you measure the pressure for all 4 tires before and after each session (just be safe)
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Dec 21 2015
    Thank you! Temp would not be high since winter is not over yet. So work your way up is better compare to work way down right?
    Quote Originally Posted by dazed1 View Post
    Dec 21 2015
    Thank you for your input! One question, since your front and rear pressure are close, do you feel more understeer? tire rack suggest high front low rear to reduce understeer.
    Quote Originally Posted by xuandatou View Post
    Oct 17 2012
    NoCal
    Quote Originally Posted by mousewei84 View Post
    You would experience understeering anyway
    Unlike R-compounding tires, PSS is not very sensitive to pressures, but according to my own experience, 40F39R setting (when hot) grips the best and do not forget to leave your ESP at the Sport Mode
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Sep 06 2014
    Wellsboro
    I agree with these target pressures hot at the end of a session. How low you need to start cold to end up at these pressures hot depends on all of the variables listed by dazed1. I start 33f/32 r during summer at Watkins Glen for first session, the adjust to reach targets. Usually need to change over course of day as track and air heat up.
    Too little pressure up front and our heavy cars will cause rolling over onto shoulders of tires; to much and things get squirrelly.
