Results 1 to 12 of 12
    Established Member Two Rings Hellahashtags's Avatar
    Jan 05 2016
    Alu Kreuz - downside?
    Just installed the EC Alu Kreuz on my B8.5 S4. I recognized the cornering benefits immediately, just as expected. However, I also feel like my ride quality has suffered slightly; and I don't know if it's only in my head or not.
    Anybody else recognized this downside with the Alu Kreuz before? My car also has H&R OE springs / adaptive dampers (usually set to "Comfort").
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    its possible. two things, alloy tends to transmits vibration more than steel does. (like on bike frames) Also you are tightening things up and tying things together more tightly, and that can transfer more noise vibration and harshness to the chassis and passengers. I would not think it would be a day and night thing, but like having 4-5 more pounds of air in the tires. I beefed up my stock steel brace with a few more square tube bars that i welded to it, and did not notice any major difference in vibrations, just a tighter front end.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Didn't notice a decrease in ride quality with the AK on my B8.5 S5.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    I remeber reading that the stock brace is designed to collapse and direct the engine towards the ground in a front end collision. Some people said the AK would prevent this and could cause the engine to be pushed into the cabin in a bad enough crash.
    Sent from my Note 5
    Bryan
    Nov 12 2015
    Here
    So, then, whether you install one of these really depends on how much you value:
    a) your own life and those of your passengers, versus
    b) an incredibly minor increase in chassis stiffness
    Mein ist grau
    Senior Member Two Rings jcdeng's Avatar
    Jan 04 2016
    2013 S4 DSG 2017 G63
    Quote Originally Posted by brainpan View Post
    Sent from my Note 5
    did it actually happen where someone with AK experienced a bad enough frontal crash that the engine got pushed into the cabin and the same person survived to tell about it? or its just speculation?
    2013 S4 prestige S-tronic, APR STG II with TCU tune, AMS Alpha cooler, ECS intake, Milltek Valvesonic, ECS skid plate, CR-15, RS4 front bumper, 034 X-brace, 034 RSB, KW V2, ONEighty custom headlights, custom 19" Work Emotion CR ultimate. Brembo 380mm front, ECS 2 piece rear.
    Apr 11 2010
    sk8 banana
    ontario
    Quote Originally Posted by jcdeng View Post
    Just speculation AFAIK
    Sent from my Note 5
    Bryan
    Veteran Member Four Rings Joker S4's Avatar
    Jun 21 2014
    B8-S4/Q5
    Mid-Atlantic
    Interesting information regarding a front end crash. I didn't think about that aspect of it. But to the OP, I did notice a slight difference in ride quality as you stated, but I enjoy what call a decrease in ride quality.
    I'm having my cup kit installed this week (H&R OE/Bilstien). Maybe I'll notice more after those are installed.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Jun 17 2012
    Dallas TX
    No downsides here on my b8. Actually AK was the first mod I did to rid of the 'floaty' steering response.
    Funny how much a brace can change driving dynamics.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Sent from my Note 5
    Sent from my Note 5
    Yeah, pure speculation. I'm sure it alters the crash behavior somewhat, but it doesn't prevent the engine from dropping down, because if you actually look at it you realize that it doesn't sit below the engine. It sits below the transmission past the firewall. There's nothing below the engine other than the belly pan since Audi mounts the engine in front of the front axle. Not sure how folks came up with this theory given where it is actually located.
    Here's a good picture of where it is located in relation to the engine. The engine would have to snap the sway bar first before it hits the AK.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Jan 24 2014
    United States
    Right but the engine and trans will move under the car as a unit. The ak would prevent that from happening
    Jan 07 2013
    Quote Originally Posted by LaCross View Post
    If that was the case, then the beefier RS5 brace that closely resembles the AK's basic shape would have the same problem. The S4's brace is not designed to fold up under impact, it's just less rigid w/o the side beams.
    S4 brace next to AK:
    RS5 brace next to AK:
