Results 1 to 25 of 25
Thread: APR TCU Tune
    Established Member Two Rings roydle's Avatar
    Oct 25 2015
    FL
    APR TCU Tune
    I have read several threads that state APR TCU tune has lots of issues. That APR states "working on it" when customers encounter problems. Is this common or only some people that encounter issues? Is the GIAC DSG tune better and more reliable? This will probably dictate my decision on which ECU software to get. I want to hear feedback from actual users. Thanks
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    100% happy with mine. No "issues" here. Read some threads but nothing jumped out at me. Well worth it IMO.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Feb 20 2006
    NC
    I've driven an apr car with no issues, but plenty are experiencing it. I would go with EPL since you can flash from home and the tune is always evolving, where I doubt apr will ever invest more time in our platform.
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Same here
    Very happy with it.
    Slight issue with the launch on a 2010 with it,but it's very minor.The AMAX shifting is awesome
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    There was a thread on this and it was not just APR TCU tunes that some were having issues with. Initially it was thought to be B8.5s but then others chimed in with B8s. Also seemed like it was not across the board issue some had it some did not.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    I have a very early (2013) b8.5 and have APR Stage 2 + TCU tune with no issues. Very happy.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Established Member Two Rings wack0's Avatar
    Dec 12 2005
    Buffalo
    I have an APR TCU tune, when I use launch control it shifts weird, like its bouncing off the rev limiter or something
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    There are a few things we have to look at. APR is one of the largest, if not the largest tune file maker for this platform. So of course issues are going to be more widespread since there is more product out there. Also I suggest using the same DSG flash provider as ECU because both components reference each other and should be used together. IE APR and APR
    With this being said, all cars are different and not all cars have the same issues. It's very hard to reproduce and develop and test a fix when so many users are quick to abandon a product or simply not buy it because they don't want to be used as a "test subject"... something I can entirely understand but doesn't exactly make the advancements of the platform come any quicker.
    We have flashed so many of these cars with APR software and have never had an issue with the TCU flashes.
    There is a lot of good information on the internet, but also a lot of bad so take it all with a grain of salt :) Let me know if I can answer any questions you may have.
    Oct 25 2015
    FL
    Quote Originally Posted by Excelerate Rep View Post
    Thanks guys for the feedback.
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    Quote Originally Posted by roydle View Post
    You're welcome, hope you found it useful. If you have any questions please feel free to shoot me a PM or an e-mail.
    [email protected]
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    No issues here with APR TCU tune. Actually reflashing this week to disable auto downshift for HPDE events.
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Oct 23 2006
    2022 Chevy Tahoe, 2012 Acura MDX
    Houston
    I have the stage 2 with DSG tune a 2013. Been driving it for a few months now including track time. On the track I don't even use the paddles. Car seams to be doing just fine under the more aggressive load.
    -Beck-
    2013 S5 Estoril Blue Crystal
    2003 A6 2.7T Silver
    Apr 21 2014
    St. Louis, MO
    Have GIAC TCU tune with about 22k miles on it. Love it!
    2014 S4 Prestige - Ice Silver - Black/Alcantara - DSG - Sport Differential - 19" Wheels - GIAC Stage I & TCU tune - Audi Guard
    Veteran Member Three Rings dimonblr's Avatar
    Oct 02 2018
    Boston
    Any more long term reviews on APR TCU?
    I am on APR Stage 1 ECU. I must admit that I purchased the tune pretty much immediately after taking ownership of the car, and have not had enough time with the stock ECU tune to get to know it well. this is also my first DSG vehicle. I noticed that after flashing with Stage 1 ECU the car obviously got quicker in acceleration, but there appears to be a bit of a delay of that power delivery to the wheels under hard acceleration. This is most pronounced at higher speeds; let's say a 40 MPH WOT acceleration maneuver. In stock form acceleration was for lack of a better term - linear. After the tune, hard pressing the gas pedal at highway speeds drops a gear down, but the full 'kick' of acceleration is in a strange way delayed by some fraction of a second. This is something that I am struggling to describe in words, but feels like a slingshot effect. Can anybody relate to this symptom and comment on wether a TCU tune addresses this?
    This attached video that I came across is a review of a different brand of TCU software available for our cars and touches on a point about TCU tunes offering a "Clutch Pressure Increase to prevent slippage while accelerating". Kind of sounds like what I am trying to describe, although I wouldn't go so far as to say I am experiencing 'slippage'.
    https://www.youtube.com/watch?v=cVLuZbOqc48
    B8.5 S4 | B9 Q5 | IG: @dmzb8s4
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Quote Originally Posted by dimonblr View Post
    I had the "delay" you mentioned while the car was 100% stock. After APR Stage 2 + TCU, it's gone.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    APR UltraCharged w/APR TCU Tune. No issues to report for me. I've have the TCU Tune for well over 10k miles.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Veteran Member Three Rings englishbay's Avatar
    Sep 30 2009
    Vancouver, Canada
    I have the same thing and like you am struggling to explain it. I do WOT at around 30km and the engine is racing but nothing is getting to the wheels for a second or two. Never experienced this with any other car, thought it might have to do with the transmission not wanting to accept the sudden increase in HP/TQ, because when it does hit the wheels it's quite disappointing. There have been a few times when it does kick in and wow it's like a rocket, but this doesn't happen all the time. What I usually have to do is be in manual mode in a gear that is around 4k to get fast acceleration.
    I’m APR UC with the TCU tune since May, B8.5
    Jun 05 2017
    Norfolk, VA
    Might be a little off the topic, but you could try installing a dog bone transmission mount insert. From what I’ve gathered it’s suppose to help with this issue and makes shifting smoother. Fairly inexpensive and relatively easy to install, generally concidered to be a worthwhile upgrade.
    S4 B8 3.0T, Silver: Current - Sports Diff. APR Stage 1
    A4 B8 2.0T, Silver: SOLD - APR: Stage 2
    Sep 30 2009
    Vancouver, Canada
    Quote Originally Posted by Maz_Audi View Post
    I have all the inserts from Eurocode: Transmission mount, top differential, bottom differential. Also it happens when in Sport, dynamic mode, and I have the sport differential.
    B8.5 S4 DSG | APR UC/TCU | APR Intercooler System | APR Intake | Bilstein PSS10s | Ethanol Sensor
    Jul 31 2012
    Scotland
    Ok, that's interesting. I have the exact same issue (I've never raised it because, in all honesty, it doesn't really bother me):
    -be driving along at, say, a steady 40 - 50 mph
    -push throttle far and fast enough for DSG to select 3rd (I haven't noticed if I get the same effect if I down shift to 2nd, or 4th for example)
    -get about 25% of the requested acceleration immediately
    -get the remaining 75% acceleration after an appreciable time gap (maybe half a second)
    I am APR TCU tuned, but like you, got the tune not long after I got the car so I don't recall stock behaviour.
    On a related note, when I asked if TCU tune was required for stage 2 to prevent clutch slip, I was told it wasn't required:
    https://www.audizine.com/forum/showt...1#post12604070
    Aug 06 2016
    East TN
    I've noticed an occasional issue with the APR TCU tune sitting at a stop light in D. Almost like its trying to push through the brakes like a fat cammed LSx but its not actually pushing at all. A "surge" I guess? It feels like if your sitting in traffic on a bridge while traffic moves in the other direction at full speed and the bridge "flexes" as heavier vehicles drive over expansion joints. I don't know if that makes sense but if I let up on the brake enough to roll forward a foot or two or put it in neutral for a few seconds it stops. It's definitely odd but not a deal breaker I suppose. It's absolutely trans related.
    2013 B8.5 S4 DSG P+ w/ ADS. APR stage II ECU/TCU w/ CTS 187mm crank pulley, Roc-Euro Intake
    Oct 02 2018
    Boston
    Quote Originally Posted by englishbay View Post
    You're right. In some situations depending on the engine speed this does not occur.
    Might be a little off the topic, but you could try installing a dog bone transmission mount insert. From what I’ve gathered it’s suppose to help with this issue and makes shifting smoother. Fairly inexpensive and relatively easy to install, generally considered to be a worthwhile upgrade.
    Not off topic at all. That was a thought of mine as well before I read englishbay's response above where he determined that this didn't address the issue in his car.
    Quote Originally Posted by Nillamb View Post
    Would you classify this as a 'slip', or a delay? Wondering if the scenarios where this occurs has to do with power being diverted entirely (or mostly) to the rear wheels. Perhaps the Torsen Quattro system takes that split second to think about whats happening when we punch it on the highway. That answer would sit better with me than if this was a clutch 'slip'.
    Jul 31 2012
    Scotland
    A delay, not a slip. There is no feeling of disconnect between the car speed and engine revs. There's simply a lack of acceleration for half a second *after* the shift completes.
    Senior Member Three Rings Jk79's Avatar
    Sep 20 2018
    Chicago
    I also have the delay when attempting sudden acceleration, usually around the 30-40 mph range. I do recall this happening when stock. It’s more pronounced with stage 1 ECU. I was hoping the TCU tune would resolve it but it didn’t. I have the transmission mount insert as well. I believe this is caused by being in too high of a gear. Our trans will have us in 6-7th gear cruising at 40. I have found that a quick downshift from the pedal shifter right before hitting the gas solves the issue.
    Edit- I should mention I have non APR tunes. I know this is an APR thread but thought I should chime in as it doesn’t appear to be tuner specific.
    2018 RS5
    2014 S4 - EPL Stage 2+ (SOLD)
    Oct 02 2018
    Boston
    Quote Originally Posted by Jk79 View Post
    Thanks for that input! I'll have to try it out.
