Results 1 to 33 of 33
Thread: Dyno day
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Dyno day
    So I went to get all my hard work this winter tested today.I was really impressed with the numbers.If it would have been colder (was 17° today) I probably would have seen higher numbers.Did 8 runs..All really close to each other.The best run was 457awhp and 408ftlbs.Not sure how to post the link to videos or pic's..If someone can Pm me and I can send you the link if you can post them?
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Very nice! What mods do you have?
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Aug 15 2015
    2 feet
    Niagara canada
    A lot! Lol
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by Silverbullet S4 View Post
    Quote Originally Posted by s4matty View Post
    A lot! Lol
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Nov 20 2014
    New York
    A lot! Lol
    Lol what?!
    Feb 06 2014
    portland, OR
    Haha I think "everything" would be appropriate. Dual pulley non ethanol race tune I believe, could be wrong...
    Dec 19 2014
    Virginia
    I want to see the nitrous build who owns that car?
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Details overwhelming. I'm surprised OP even posted numbers and didn't just say "Dyno'd high".
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Aug 15 2015
    2 feet
    Niagara canada
    Apr stage 2t tune.Tcu tune.Water/meth
    Custom test pipes,Dp's,exhaust,Intake.Custom throttle body spacer/adapter "different "throttle body.Custom ground cams.
    Aug 15 2015
    2 feet
    Niagara canada
    Oh and my custom crank pulley.
    Jun 12 2015
    CA
    Which dyno?
    Aug 15 2015
    2 feet
    Niagara canada
    Dynojet
    Aug 15 2015
    2 feet
    Niagara canada
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Link doesn't work.
    Aug 15 2015
    2 feet
    Niagara canada
    Ya someone sent me the link,but it's not working.I will get some vids up soon.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    That is a lot of custom! If this is legit you have my interest. I have felt that cams could be a game changer on this motor.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by cspcrx View Post
    Yes it is a lot of work..I didn't really want to post up saying I made this and that..etc.
    Still more to be made without tuning!
    I do not run race gas also..Pump only and meth
    Aug 21 2014
    Boston
    Would definitely like to know more about cams for the 3.0, also would like to see pics/know more about the W/M setup.
    2015 Ibis White S4 DSG
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Nice! Good for you for doing some custom stuff. This is the first I have heard of cams for this motor. How did you not make a build thread when people here make lame-ass build threads for installing bolt-ons?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by Hofahome View Post
    Thanks.
    I didnt really think about making a thread. Jst had fun making some different parts for this car.And it's pretty rewarding when you get some decent gains from your own work..I'm going to do some changes to another set of cams again and go back to the dyno next week..Different day/weather plays a factor though.Still can't copy/paste the links for some reason?
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Edit: Not my car, but Matt's
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Aug 15 2015
    2 feet
    Niagara canada
    Awesome thanks Your the best!!
    Jan 04 2013
    Phoenix, az
    Seeing a lot of hoses and tubes that causes a lot of questions.
    Intake looks like a tube or hose with no filter. Is this correct?
    Looks like your running some type of cooling hose up to the top of the TB? What is this? Much to large to be simple meth injection. Looks like a cooler or something?
    None of this looks streetable. Was this a test to see what max power you could achieve is?
    Aug 15 2015
    2 feet
    Niagara canada
    Nope I daily drive this..I made that intake awhile ago.It uses a 5" filter at the end.I only had the filter off to make sure the 1st stage of the meth was spraying..2nd stage is in the throttle body.Not sure what large cooler you are talking about?
    Aug 15 2015
    2 feet
    Niagara canada
    Gained nothing when I took the filter off.BTW
    Jan 04 2013
    Phoenix, az
    Its laying across the top of the motor coming from the front of the car.
    Aug 15 2015
    2 feet
    Niagara canada
    That is just one of the shops fans to help cool the motor..They only use a small fan for the rad and this small air duct..Not even sure why they use it.Doesn't really blow much air at all.And the silver intake with the velocity stack was only used to see if it made any difference (it lost 8hp)BTW with that setup
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    Neetronic's dyno reads high, multiple cars I've tuned on there showed the same thing. Not taking away from your power/mods just saying dont read too much into the higher than normal whp, we all know ET/MPH tell the truth.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Account Suspended Three Rings
    Oct 15 2015
    Your right and when the track opens up. Im sure he will be one if the 1st to get out there and run the vehicle. But I also haven't heard any other complaints from anyone else about neetronics dyno.... Maybe you had a bad experience with them?!
    Jan 04 2013
    Phoenix, az
    Cant wait to see more!
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by Kustomimports View Post
    April 10th✌
    Apr 06 2016
    Ottawa
    Ya if the snow has melted by then
    Jan 04 2013
    Phoenix, az
    97 degrees here yesterday and you talking about snow! crazy!
