Results 1 to 19 of 19
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    Power Steering Whine, only when in gear
    Halo,
    My power steering lets out a high pitch whine, but only when it's in gear.
    I recently replaced the line about 3 months ago, seems to be getting worse.
    I also drove w/o power steering for probably too long (maybe 20 miles), before replacing that line.
    Any thoughts?
    ~ ea
    Sep 27 2015
    OH
    Check fluid level
    Veteran Member Four Rings AudiB5owner's Avatar
    Sep 08 2011
    B5 A4 1.8T AWM FWD
    Los Angeles, CA
    Can be a few things. Put the car in neutral and turn the wheel all the way to one side. Apply some thorttle and see if it makes the whining. The pump may be going out. You can also use a mechanic stethiscope to listen to the pump. Are there bubbles in the res? Like ^ said, is the fluid low?
    B5 A4 1.8T FWD
    Apr 22 2014
    Aptos, CA
    Quote Originally Posted by AudiB5owner View Post
    Fluids good Just did the test, certainly whined when applying throttle / turning wheel. Pump?
    Apr 22 2014
    Aptos, CA
    Jun 03 2013
    Nanaimo, BC Canada
    I used to run chf11s in my power steering pump and it began to make this noise, gradually got worse over a couple months. At first I thought my transmission was whining but it becomes obvious. At first I changed out the reservoir fluid a couple of times with fresh 11s. Didn't make a difference, obviously it had already worn to the point of making noise. I changed that out with Pennzoil Full Synthetic Multi-Vehicle ATF and it is silent now. No leaks. I would never recommend regular ATF as these pumps work best with a fairly thin synthetic fluid. I think the anti-wear additives in syn atf are a lot better and more modern. CHF11S is a great fluid for extreme cold but it doesn't seem to protect the pumps that well at high mileages.
    Oct 21 2005
    y
    Only in gear? One specific gear or all? One specific gear could be the gear itself. Whines, specially under load, right before it loses all its teeth.
    Could also be the mounts.
    Apr 22 2014
    Aptos, CA
    Thanks for the replies guys,
    So ben2401, you're saying use different Tranny Fluid or Power Steering Fluid?
    ricekikr: Seems to be every gear. Only whines when the wheel is turned, gets higher pitch/louder with speed. Also subtly moans when out of gear.
    & The tranny mounts?
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Mine whines for the first 5-10 minutes after a cold start driving, when the car is up to temperature its completely quiet. I do have a very small leak. I think my hoses are porous and possible original.
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Apr 22 2014
    Aptos, CA
    Quote Originally Posted by elisagrace View Post
    Power steering pump that is low on fluid cause it to whine. What happens that power steering system develops a leak in the steering gear or rack rather than in the pump, while searching for a leak that would be the best place to start looking. Once you find the place next step is to stop the leak. Driving during leakage is very hazardous. As you have mentioned that you have replaced the line 3 months back, you must visit the concerned mechanical shop and tell them the issue , they will certainly repair it. Still if the problem is not rectified you can visit here https://www.yourmechanic.com/cars/audi.
    Fluid level is okay will monitor it though... thanks for the reply.
    - - - Updated - - -
    Quote Originally Posted by SN95Audi87 View Post
    Gotcha.
    Any more word on if my pump is going / bad?
    Apr 26 2010
    North Jersey
    Quote Originally Posted by b5a4erik View Post
    - - - Updated - - -
    Gotcha.
    I doubt its going bad just noisey enough to notice. I believe if it was bad it would whine all the time really loud but it goes away. A fluid swap and some new hoses should remedy the problem.
    Apr 22 2014
    Aptos, CA
    Ight. Yeah something worth noting is that it's not there when I just start the car, and gets worse the more/harder I drive it.
    Further insight?
    Apr 26 2010
    North Jersey
    Further insight?
    Start small and work you way up! Fluid swap, check for leaks, replace hoses if necessary. If its still whine try a fluid that can't quiet it down like others mention. If all else fails find a new one or low mileage junkyard one...
    Apr 22 2014
    Aptos, CA
    Word.
    Registered User Four Rings Pelican Parts's Avatar
    Jun 08 2015
    B7 A4 Sline, B7 RS4, '04 STi
    Harbor City, CA
    If you do find out it's the pump that needs replacing, we have some options here as well: http://www.pelicanparts.com/catalog/..._pg1.htm#item2. I'm dealing with a whine from mine right now after replacing a line and I'm hoping I wont need a pump too. Good luck.
    Apr 22 2014
    Aptos, CA
    Quote Originally Posted by Pelican Parts View Post
    Yo! An honor to get a reply from you guys, I believe I used your DIY on a Turbo Replacement a while back, seriously helped me out! Considered a reliable source to me since then, props.
    Thanks for the link, and good luck with your car as well!
    Jun 08 2015
    Harbor City, CA
    Thanks for the link, and good luck with your car!
    That's great. Very happy to hear that our articles have been useful to you. If you ever need anything please don't hesitate to give me a shout on here. Hope you get this figured out as well. Cheers!
    Sep 08 2011
    B5 A4 1.8T AWM FWD
    Los Angeles, CA
    Use a mechanic stethoscope or a really long screwdriver to listen to the PS pump, with the wheels turned all the way to one side, while hitting the throttle to raise the RPMs. If you hear a nasty grinding sound the pump can be bad. I had a nightmare with the PS system. Pump blew, messed up steering rack. Then the pump broke again and PS lines started swelling and leaking. A check valve also blew up and caused a mess. All in all it is now sorted out after I stopped using the Meyle pump and went with the Zf pump. Hope you can get it fixed man
    B5 A4 1.8T FWD
    Apr 22 2014
    Aptos, CA
