I wrote a thread yesterday but it never showed up anywhere. Basically, it feels like fuel enrichment isn't working when applying throttle. I have to give slow, gradual gas or it bucks and jerks like a horse from severe misfires. I changed the plugs, used 1 new coil from cylinder to cylinder to rule out a bad coil. I unplugged the MAF to see if it would go into limp mode and improve driveability.. Would've told me if that was the issue. I unplugged the MAP sensor and it was improved dramatically. It still misfires on the highway if I apply throttle in drive (if I throw it in S and get the rpms up, it's OK...just gutless. Had it improved completely, that would tell me MAP, but its only improved, not fixed. I'm thinking unplugging the MAP maybe richened it up and offset a lean misfire being caused by something else? Only codes were misfires...300, 301, 302 and 303, and the 238 from unplugging the MAP. I'm broke so I can't afford to just replace everything till I find the issue. Does it sound like a bad o2? What are your guys' thoughts?
