Results 1 to 30 of 30
    Deactivated Four Rings
    Jul 16 2007
    2000 A4 Avant 1.9L BT
    Irvine, CA
    Spring specials are live on many GIAC performance software calibrations!
    Spring has arrived, and to celebrate, we’re offering great deals on many of the latest GIAC performance software calibrations! GIAC Spring specials begin March 17th, 2016 and continue through April 30th, 2016 for applicable Volkswagen, Audi and Porsche models. If you have any questions regarding specials on a particular model or calibration, please do not hesitate to ask. Spring forward with more power and extra savings!
    The promotion includes 10% off MSRP* for a 91 or 93 octane performance flash on all Volkswagen, Audi and some Porsche models. A la carte switching products** (not already packaged with pump software) can be purchased at 20% off MSRP.
    All of GIAC's software offerings for VW/Audi are installed via OBD2 port flash methods, except for the Audi R8 V10 and TTRS 2.5T. Most Porsche cars can be OBD flashed with the exception of 997.1TT (engine and transmission), 997.2 3.8L GT3/GT3RS and Boxster /Cayman 2.9L calibrations, which must be bench flashed.
    The attached flyers include most US makes and models. International customers, please contact your local GIAC distributor for specials on GIAC products in your market. One is for Porsche cars while the other covers VAG platforms. Some models included in the promotion are not specifically listed there. Please contact GIAC for any pricing confusion.
    GIAC’s software switching is the quickest, most seamless program switching option available for VWs and Audis on the market. Users can switch programs on the fly with a single push of a button, and without the need to cycle their ignition. Fully loaded offerings include a GIAC Flashloader Handheld Program Switcher and all available switching modes (unless otherwise noted):[/B]
    Available Options in addition to 91/93 octane performance modes:
    • “Stock” mode: reverts vehicle to stock performance levels
    • 100 octane performance: higher performance calibrated for 100 octane. Can be used with 50/50 water meth on some models
    • Valet: Zero boost & lazy throttle response make the car more of a burden than a joy to drive.
    B8 A4 2.0T 6MT Quattro Software only
    B8.5 Allroad / A4 / A5 2.0T Tiptronic Quattro Software only
    * Manufacturer’s Suggested Retail Pricing. Actual retail pricing may vary.
    ** FHH Switcher options may include Stock, Pump (91/93 octane performance), Race (100 octane), Kill (anti-theft feature), Valet (reduced power), & Privacy Firewall (PIN security for FHH which locks out other FHH switchers. Pricing includes only currently available options for each platform or model.
    Senior Member Two Rings redeye_jedi's Avatar
    Dec 12 2015
    Sk8teboard, Audi B8 A4 Quattro stg2
    Would I just talk to my local dealer for these prices or you guys directly? How much do the access ports cost?
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by redeye_jedi View Post
    The switchers are $150 new. I've got on and have only used it to switch programs 4-5 times in the year I've been tuned. Good to have, and works well, but you don't need it right away, except as a novelty.
    #pedalresponce
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Established Member Two Rings dbv2's Avatar
    Mar 06 2016
    To
    I've been wanting to look more into tuning my B8 that I just picked up. Theres many options out there for tunes, but I'm afraid of the void TD1 of my warranty.
    Will this on the fly module prevent my dealer from plugging in my B8 and automatically branding my car TD1 due to the tune. Obviously assuming that I returned to the stock values with this module.. I've inquired into my local APR guys and they're all telling me I'd need to re flash everything I were to go in for service, thus ending up in a very expensive process in the long run. None of them have mentioned of a on the fly tune module such as this.
    I will have to look up if there are any GIAC dealers near me..
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Quote Originally Posted by Austin@GIAC View Post
    "**Sales excludes FHH handheld switcher device hardware." Show what do you get with this 20% off switching options?
    The flyer header also makes it seem that you would get 20% off your entire purchase, but the surrounding text does not support that. Maybe it's me, but I read that as 20% off your purchase or ($495+$150)*(.8) = $516 + tax; which isn't the case when you read the text.
    Quote Originally Posted by dbv2 View Post
    There's one in Buffalo, NY...but good luck getting a hold of them. I have called them 3 times on separate occasions a few months back, and they have never answered. They finally called me back after my third message, but their hours are the next issue (not GIAC's fault). Monday - Friday, typical business hours and they said they won't consider a Saturday or later on a weekday. Not to mention the labor charge (again, not GIAC) for a OBDII 30 minute flash. Hopefully you have better luck! I mention this dealer because its probably the closest to you that is in the US; which the flyer specifically mentions.
    Edit: Called them today and the labor charge is $100
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    does "pump" have a specific 93 octane mode the way APR has modes for 91 vs 93? We have 93 here in boston not 91 so I'm wondering if the software takes advantage of that
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Oct 26 2012
    St. Louis, MO
    I don't think the switching tool reverts the car back to stock and rolls back the flash counter. You'd need a full reflash to avoid TD1.
    #pedalresponce
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by bakedziti View Post
    $495 is already 20% off, you'd need to use $550 in your calculation....
    #pedalresponce
    Oct 23 2014
    _
    Quote Originally Posted by blbroo View Post
    #pedalresponce
    $55 off of $550 is 10%
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Oct 26 2012
    St. Louis, MO
    #pedalresponce
    Oct 23 2014
    _
    #pedalresponce
    I see what you're saying. Yeah, the calculation should be ($550+150)*(.8)=$560+tax, because the $495 is already discounted at 10%; but that isn't really what they are offering. The original post states that its 20% off the switcher (not sure if that's the handheld based on the fine print in the first image, which is different than the fine print at the bottom of the original post) and 10% off the tune. It would actually be $550*0.9 = $495. $495 + ($150*.8) = $615 +tax.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by AllroadCorbin View Post
    We have files for both 91 and 93 octane. The dealer will select accordingly based on what your native premium fuel is.
    Jul 16 2007
    Irvine, CA
    Yes, you would speak with your local GIAC dealer and they can install the software for you.
    Oct 26 2012
    St. Louis, MO
    Even for a B8.5 Allroad? Or is that just 91 or E85?
    Active Member Two Rings FastFour's Avatar
    Feb 15 2016
    2015 allroad 2011 BMW 335d 2007 Honda S2000
    Once this this software is loaded are you able to bring it back to stock configuration w/o the dealer recognizing that it was ever flashed?
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    Whats up with the E85 tune? Im lazy and didnt search....us vets are allowed 2 per year, back off trolls ;)
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    #pedalresponce
    They have a wireless Bluetooth app that can change modes wirelessly....
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Established Member Two Rings kshup2me's Avatar
    Feb 06 2012
    Toront , Ont
    Quote Originally Posted by FastFour View Post
    Someone correct me if i am wrong because i have been wondering the same thing, have talked to a couple shops and they seem to say that audi can detect any tune if flashed back to stock as they can check the counter. APR for sure this is the case , i was pretty disappointed as i was hoping to flash my newly acquired A5. I am hoping ( slimly ) that GIAC breaks this rule and can somehow go undetected but i don't believe so!!
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by kshup2me View Post
    It's possible for them to catch any tune, unfortunately. That said, any tune makes these cars tons of fun.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Oct 26 2012
    St. Louis, MO
    @austin@giac I have had no issues with my stage 2 and the car runs great. However, many people I talk to are hesitant to try GIAC because there is so little information on your websites.
    Stage 2 is available for non E85 B8s and B8.5s but it doesn't show on the website and there are zero dynos available for it. As well, there is no pricing shown on giacusa.com. Someone has to call an installer to get that.
    I think I have been the loudest and most positive GIAC customer on AZ and wish there was better data to back me and have others join me.
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    I'm one of those guys. Going stage two any day. Can you please post some useful info regarding your product?
    Pedal Responce first responder.
    Jan 03 2012
    Wilmington NC
    This!!! And where is the E85 support!?!? I have to go with APR because of this.
    2019 S4 Build
    IG: @steves_s4
    Sep 03 2012
    Lehigh Valley, PA
    Quote Originally Posted by SleeperCar View Post
    - - - Updated - - -
    There is e85 support... They claim 320hp flywheel on e85.. Its on the switchable 100 octane e85 race mode
    Jan 03 2012
    Wilmington NC
    Quote Originally Posted by hyperunion View Post
    There is apr support... They claim 320hp flywheel on e85.. Its on the switchable 100 octane e85 race mode
    - - - Updated - - -
    Yea but the problem is I don't want to run 100 octane...
    Apr has it setup for 93 octane and switchable to E85
    And if they do, where the hell is the information?
    2019 S4 Build
    IG: @steves_s4
    Jan 03 2012
    Wilmington NC
    - - - Updated - - -
    It's ok, I'm just going to call GIAC on Monday...
    Their website is really just not cutting it for me.... I know we all are sensitive to big marketing budgets (cough apr cough) but GIAC website is on the complete opposite end of that spectrum and it's a bummer.
    2019 S4 Build
    IG: @steves_s4
    Veteran Member Three Rings PBKIDD24's Avatar
    Apr 30 2015
    I have to agree that GIAC makes a great product which I have had ZERO issues with, but their website and marketing is pretty terrible. Even the dealer locater on the website is not up to date. I am about to install a HFC and go stage II but am unsure if I am going to stick to GIAC due to the lack of information; I am still unaware if they even have a stage II file for B8.5. As for E85, they have a separate map that REPLACES the 100 octane map and is stored under the "race" mode on the flash loader. The main difference with GIAC E85 map is that the user has to manually change the map when running E85, while APR switches the map using the ethanol sensor.
    2015 S4 P+ Daytona Grey Pearl Effect
    APR / Milltek / Bilstein / Eibach / 034Motorsports
    Build ThreadInstagramFlickr
    Past Cars: 2015 A4 Build Thread
    Active Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    Quote Originally Posted by PBKIDD24 View Post
    I heard the opposite, APR you have to manually switch over to the map when running E85. (Not sure, don't quote me on it) I'm also 80% sure GIAC doesn't have stage two for the B8.5s...
    Jan 03 2012
    Wilmington NC
    Quote Originally Posted by AUDIMAN33 View Post
    Apr uses factory sensor to automatically sense ethanol content, and it adjusts power accordingly, 100% confirmed on that
    2019 S4 Build
    IG: @steves_s4
    Oct 26 2012
    St. Louis, MO
    I would like to see some sort of proof that I have a stage 2 file and not just "xplus". Doesn't make sense that the website shows x2 for GTIs of the same years but "isn't updated" to show it for ours.
    Sometime the power feels strong, sometimes I can't tell a difference switching between any modes, even stock.
    Apr 30 2015
    This is exactly how I feel. How am I supposed to spend money on a file that doesn't have any information available to me, not even a dyno graph?
