Results 1 to 14 of 14
    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Exclamation Ton Of Problems, Please someone help!
    Hello, I am starting a new thread on this. Pretty much my b6 s4 is having a ton of issues out of no where.
    I was driving home the other day and my oil pressure light came on and the car started driving really weird. The clutch pedal was vibrating pretty bad when pushed in and only when pushed in. Also if i was accelerating, as soon as i let off the gas pedal the car would jerk real hard. It is now parked in the driveway until i can get to the bottom of this.
    When i go to start the car, it runs for a second then immediatly shuts off so I scanned it with Vagcom with my foxwell and Its throwing a bunchhhh of codes that werent there before. Here is a list of all the codes...
    01-ENGINE
    18010 Power Supply Terminal 30: Voltage too Low : P1602- Static - No Fault Type Identified
    18048 Internal Contr. Module (EEPROM) Error: P1640
    16524 Oxygen (Lambda) Sensor B1 S2: No Activity : P0140
    18044 Powertrain Data Bus: Missing Message from Airbag Controller : P1636
    18036 Powertrain Data Bus: Missing Message from Steering Angle Sensor : P1628
    18057 Powertrain Data Bus: Missing Message From ABS Controller : P1649
    18107 Powertrain Data Bus: Missing Message from Steering Wheel Electronics : P1699
    18043 Powertrain Data Bus: Missing Message from A/C Controller : P1635
    18058 Powertrain Data Bus: Missing Message from Instrument Cluster : P1650
    16885 Vehicle Speed Sensor Implausible Signal : P0501
    17978 Engine Start Blocked by Immobilizer : P1570
    03- ABS BRAKES
    18262 Powertrain Data Bus: Hardware Malfunction : P1854 Intermittent
    18031 Powertrain Data Bus: No Communication : P1623 - Static - No Indication on Display
    00778 Steering Angle Sensor (G85) - Static - Implausible Signal
    08- Auto HVAC
    01312 Powertrain Data Bus - static- Interrogate fault memory
    09-Cent. Elect.
    01312 Powertrain Data Bus - static - Interrogate fault memory
    01326 Control Module for Multi-Function Steering Wheel (J453) - sporadic - No Communication
    0F- Digital Radio
    02635 Tuner Not Enabled Activated - static - No Indication on Display
    15-Airbags
    00474 Control Module for Immobilizer - static - Interruption
    00532 Supply Voltage B+ - static - No fault type identified
    17 Instruments
    01314 Engine Control Module - sporadic - No communication
    01316 ABS Control Module - sporadic - No communication
    01312 Powertrain Data Bus - sporadic - Defective
    25 Immobilizer
    46 Central Conv.
    01134 Alarm Horn (H12) - static - No communication
    00955 Key 1 - Intermittent
    55 Xenon Range
    00532 Supply Voltage B+ - sporadic - Signal too low
    Anyone have any clue what the issue could be?
    Established Member Two Rings Ob3R's Avatar
    Apr 29 2013
    '17 RS3/ '00 S4/
    Omaha, Ne
    Wow, never seen that before...
    Maybe something to do with ECU? Water or bad harness is short circuiting the ECU and therefore thats why you have codes for most if not all modules?
    Again just a guess. I would open up the ecu box and see if theres anything wrong in there.
    Sent from my .:R32
    DD: '17 RS3
    Project: '00 Audi S4 6MT Imola Yellow
    Previously Owned: Too Many...
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    get the multimeter out !
    good luck!
    (start by the basic stuff)
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I had the ecu out, everything looks good. I need to grab a multimeter today. What should I be checking with it and how
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Anyone?
    May 18 2012
    2005 S4
    Portland, OR
    I'm not much of an electrical expert but it seems like insufficient voltage to the ECU is causing issues. You really need the wiring diagrams (included in the Bentley guide) so you can check voltages at the pins that supply the ECU, at least as a start.
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Bentley manual seems like a must with this vehicle. Hopefully when my engine is back in, I don't get to many codes! !! But I expect some after doing an engine pull.
    OP: I'd bring that to a dealer TBH.
    Sent from my SM-G900T using Audizine mobile app
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    that many different codes/no communicates generally indicates a bad battery (voltage too low) or a missing ground or power wire. something big is disconnected/shorted somewhere
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by bmwpower603 View Post
    I was expecting lots of codes too when I restarted my car after doing the timing in it , but the only codes I had were SAI related (deleted everything).
    just make sure you plug every connector back in, and make sure they all "click", lol
    and my throttle was all over the place somehow (stalled when I gave it gas/weird behavior)
    . . . had to do a quick throttle body alignment and it was fine after.
    Jun 07 2013
    West
    Battery going dead - voltage drop. That's all. Happened to me. Get this battery at AutoZone:
    http://www.autozone.com/batteries-st...?checkfit=true
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I was thinking this the other day, but have kinda let go of the idea. Thank you very much!
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I got the battery tested this morning at advance auto and it came up good, but low on voltage. Fuck meeeee idk what it could be
    May 18 2012
    2005 S4
    Portland, OR
    The battery tested low on voltage? Replace it and see where you're at. A lot of this power supply stuff is pretty much straight off the battery. If the supply voltage is low, it's a very good chance the battery is the culprit.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I let advance slow charge the battery for 5 hours today, got it back at 12.6v 866cca. I put it in the car, the immobilizer still kept it from starting, and I checked with the multimeter it went back down to 12.2. I just want to be sure before I buy the battery
