Results 1 to 11 of 11
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    Help identify B5 airbag wires for FBMFSW retrofit
    I need to id the wires on a B5 and 8V airbag.
    B5:
    Blue - Airbag 1?
    Brown - Airbag 2?
    Purple - horn?
    Green - horn ground?
    I don't want to explode the airbag after re-pinning the harness.
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Blue is definitely airbag and brown is definitely airbag ground. I'm not sure about purple/green though.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    May 08 2014
    CLFX, Denver
    Help id B5 airbag wires
    Thanks melo. I'm trying to retrofit an 8V airbag on an S3 wheel. This is how I have it wired now.
    B5 8V
    Horn | purple | blue
    Horn ground | green | brown
    Airbag | blue | green
    Airbag ground | brown | black
    Nov 08 2010
    Upstate New York
    Where'd you get the S3 wheel if you don't mind me asking? I really want to get my hands on one. I've been struggling to find another one at a decent price after I watched one slip away in the 8V classifieds.
    - B8 S4, Stage 2+
    - B6 S4, not stock
    Jun 10 2010
    May 08 2014
    CLFX, Denver
    Um, no. That's where I got the idea.
    Jun 10 2010
    Okay.
    May 08 2014
    CLFX, Denver
    Okay.
    Thanks for your contribution. When I figure it out, I will post a short diy. I think I'm close.
    Apr 02 2013
    above top secret
    Quote Originally Posted by HUFset View Post
    Can't wait for the guide. However can you use the passat b5.5 airbag harness? It looks more plug and play
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by maxiz1 View Post
    I think they are the same connector. I've looked through passatworld for some sort of DIY but I think their airbags are different because of 4 spoke wheel design and multifunction buttons. It depends on the clock/slipring terminals. I just don't know which wires are airbag 1/2 on 8V single stage airbag. I'm fairly certain I know the B5 A4 airbag1/2 and horn/ground from previous DIYs on AZ and Vortex.
    May 08 2014
    CLFX, Denver
    The pic is incorrect, I had the horn wires pinned backwards in the B5 harness. I successfully installed my 2013 SLine A3 FBMFSW with 8V single stage airbag into my B5 A4 this weekend. The following pic is the schematic for a re-pinned and WORKING B5 airbag harness with 8V airbag wires.
    Wire/Pin B5 8V
    1 Airbag ground | brown | black
    2 Airbag | blue | green
    3 Horn ground | green | brown
    4 Horn | purple | blue
    5 Empty
