    Junior Member One Ring
    Mar 07 2016
    Florida
    2016 SQ5 APR Stage 2 Long Crank Issue?
    I have a 2016 AQ5 with an APR tune and pulley. It takes 1.5-2 seconds or so to start the car. When it's hot it's worse.
    It didn't go this when it was stock.
    I contacted APR and honestly they are not great at returning emails. Not the best customer service. It seems like they just don't care. Not cool APR. Justin emailed me back ONCE and then never again. Not cool Justin.
    I heard this happening to some VW's as well. Anyone else have this issue? It's pissing my wife and I off. Long cranks are NOT good for a cold engine.
    Senior Member Two Rings Flieger's Avatar
    Aug 15 2013
    1969 VW Kombi, 1983 VW Rabbit GTI Sport, 2012 Golf R, 2015 Audi Q5 3.0T
    Colorado
    I can tell you that with the same setup I don't have the issue, zero difference in crank time. I'd suggest you go have it flashed back to stock and see if the problem remains, if it does then take it to e dealership and have them take a look. You also need to call APR and talk to the tech support guys about the issue. It's a much faster way to get an answer to your questions.
    1969 VW Kombi | 1983 VW Rabbit GTI Sport | 2002 Audi Allroad 2.7T 6MT | 2012 VW Golf R OEM+ | 2021 Audi RS6 Avant
    Instagram: @fahren_rs6aom and @waterwerksmotorsport
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    No problems here either with the same setup.
    Are there any VAGCom error codes to go on?
    Veteran Member Three Rings JayCar's Avatar
    Dec 13 2015
    2023 Tesla Model Y Performance, 2022 MINI Cooper S Countryman, Specialized Tarmac SL4 Sport :-)
    Houston, TX
    Mine either. No issues.
    2014 SQ5/Monsoon Gray
    Go: APR Stage 2+ w/ SC pulley, Airbox mod w/ aFe hi-flow filter
    Ride: H&R Street Performance Coils, RS6 reps in Gunmetal 21x9.5 w/ Michelin PSS 285/35/21
    Look: P3 vent gauge, HID fogs, E-code heads and tails, Many VCDS mods
    Rebuild Thread
    Mar 07 2016
    Florida
    Thanks for the replies!
    Wierd as most of the SQ5 owners at Audiworld say their cars always have long crank times.... check it out here.... http://www.audizine.com/forum/showth...g-Crank-Issue?
