Results 1 to 12 of 12
    May 29 2009
    Cincinnati Ohio
    Knocking Noise UGH!!!
    I need a little help here, the car sits throughout the week. I went out this evening to drive the car and when I turn the key to the first position (accessory position) i hear a knocking noise for about 5 to 10 seconds. Then goes away, car runs fine and seems to be no other issues.
    Any suggestions?
    Dec 07 2009
    East Coast
    Where do you hear it's originating from?
    Forget the B8, keep the V8!
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    It's the squirrel getting into his running wheel!
    Yea! where's the noise coming from? The back seat, behind the dash or the engine compartment.
    May 29 2009
    Cincinnati Ohio
    I needed that. Sounds like from the engine, I did some more research and need to look into the fuel filter. Car has 70k miles
    Checked the wheels yup no squirrels. Haha
    Mar 10 2010
    WI
    Umm..ok. But the fuel filter is behind the rear seats, in front of the rear axle. When the key is turned to on, the fuel pump engages and makes more of a buzzing or humming noise rather than a knocking noise. With 70k, it is a good time to replace the fuel filter and should help with quieting down the pump.
    Senior Member Two Rings icanfly's Avatar
    Jan 12 2012
    06 B7 S4 | 92 Corrado SLC VR6 | STI Powered HandBuilt TarmacRallyCar | Skydiving Rig
    Looking for a canyon to carve.
    Video the noise and post it?
    that's about the only thing that will help with an internetiagnosis.
    slow is fast...
    Veteran Member Three Rings sitting proper's Avatar
    Jan 22 2013
    Pittsburgh
    If it's a slow knocking, it could be your heater or AC unit engaging. I have that happen sometimes when the key is in accessory. Mine only happens about 3-5 times though.
    Past - '07 S4 Imola Yellow Avant, '06 S4 25quattro Avus Silver
    May 18 2012
    2005 S4
    Portland, OR
    I had the same thing happen to mine a couple of times and it was definitely loud enough to be alarming. Seriously sounded like someone beating on something. To me, it sounded like an underhood noise, but I also read that the fuel pump could make a "slapping noise" on startup if the filter was starting to get gummed up. I replaced my filter because I figured it probably needed it in any case, and I haven't had the issue a single time since. However, I also haven't started it that many times since then because it has been torn apart for various repairs over and over and over...
    May 29 2009
    Cincinnati Ohio
    Thanks for the responses, I am going to replace the fuel filter since this service is due. I called the local dealer since I need the part asap, gave them my vin number and they were unsure if I needed the four port or three port fuel filter. Anyone know what filter is needed on a 2006 s4.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Quote Originally Posted by djmilleroh View Post
    Just look at it, it is right underneath the passenger rear door.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    May 18 2012
    2005 S4
    Portland, OR
    Apparently there was a weird VIN split thing with the filter and even ETKA will tell you the wrong part number on some cars (I can verify this happened to me). The filter is pretty easy to see though, so just go take a look and visually verify the line quantity.
    May 29 2009
    Cincinnati Ohio
    Update: thanks guys swapped out fuel filter this weekend and I'm back up and running.
