The ignition switch has a "Key IN" switch. It closes once you insert the key and turn it a bit. Then it opens when you pull the key out (make the ka-chunk noise). You can feel this - after removing the key if you insert it and remove it again (without turning): no ka-chunk. That's the key-in switch...not doing anything. When you drag the key out (notice the extra friction) and get the ka-chunk, that's the key-in switch doing its magic.
I think it would be easiest to hook up to the Key-in switch output (direct 12v+), put a fuse in-line (because safety) and connect that to your head unit's "ACC" wire. BAM, done.
Note: If you shut the car off and leave the key in - your radio will stay on and turn your battery into a boat anchor. If you want a timer function, or if you want it to cut power when you open the doors - you will need to get power somewhere else. It just depends how you want it to behave.
Note 2: I have never done this. I do not install car stereos for a living. I do not get paid to work on cars. I do not get paid to work on stereo equipment. I am barely qualified to tie my own shoes. The above is just "what I would try first", if I had a B6 and wanted accomplish the key-off, radio-still-playing thing. There may be an easier way, but this way does not add load to various module-controlled outputs or anything. It just taps off the existing switch output.
