Results 1 to 6 of 6
    Established Member Two Rings SilverRings's Avatar
    Aug 20 2015
    Louisville, KY
    Spark Plugs Difference
    NGK Laser Platinum PFR8S8EG (OEM) or NGK Iridium BKR8EIX? Both are said to work in our cars, but the Iridiums are half the price.
    Longer lasting? More reliable spark in the Laser Platinums? What is the difference between these plugs? Any of them better for a stage 2 car?
    2011 Audi S4 // P+ // Sport Diff // DSG
    EPL Stage 2 and TCU | AWE Touring Exhaust | 19x10 et42 Forgestar F14s | Ventus V12 255/35/19 | KW Street Comfort Coilovers | EuroCode Rear Sway Bar | EuroCode Trans/Diff Mount Inserts | EuroCode Alu Kreuz Driveline Stabilizer | CR15 Strut Tower Brace | StopTech SS Lines and Fluid | Akebono Euro Pads | Centric High Carbon Discs
    Senior Member Two Rings UberBrute's Avatar
    Jan 05 2014
    E91 BMW 328xi 6MT
    Connecticut
    anyone know?... I have the same question
    Sent from my Nexus 6 using Tapatalk
    SOLD 2013 Audi S4 | 6MT | Estoril Blue Crystal | Premium Plus | MMI Nav Plus | Sports Differential | Carbon Atlas Inlays | Alcantara inserts | 19" Peelers |
    Mar 21 2015
    Theres a few spark plug threads. Search a bit.
    Aug 20 2015
    Louisville, KY
    Went through all of them before I posted, but the only conclusion was that you could use them. No one talked about results.
    Mar 21 2015
    Gotcha
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    FWIW, Copper is a much better conductor than Iridium and Platinum. It is generally used in high performance/modified engines running higher boost. For example my turbocharged B5, I use NGK-BKR7E's (copper plugs) which is one heat range colder than stock and gapped specifically based on best results from my tune manufacturer (GIAC). One caveat for copper plugs is that they erode faster over time vs Iridium/Platinum. I tend to switch them out every other OCI.
    So to answer your question, Iridium and Platinum plugs are typically chosen for their longevity. I'm too early in my B8.5 S4 ownership, plus I'm not tuned to switch from stock plugs. Would stick with what your tuner would recommend (since your stage 2) otherwise, default to what manual calls for. The claims by parts stores to upgrade to the Triple-Spark Ultimate Unobtainium plugs are typically just upsells.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
