Results 1 to 21 of 21
Thread: Ac problem
    Oct 19 2013
    Saint James ny
    Ac problem
    Heading to work today and the Ac doesn't work? I brought it in over the winter for audi to check because one day my windows were fogged up and wouldn't defrost, it happened on a couple occasions . Off course it worked fine when I brought it in and they found no problem. Has anyone experienced this problem?
    Jan 22 2015
    Mississippi
    I had to get my compressor switched out last year. Took about 1 1/2 months back then to get the new compressor and then they didn't order bolts and then they broke a bolt and then they had to replace something else. It was a nightmare. AC works great now though.
    Veteran Member Three Rings deadbolt's Avatar
    Aug 29 2014
    NY/LA
    I had an issue with my AC as well. I was lucky enough that the compressor did not need to be replaced but the N280 valve was replaced. I haven't been able to really test the AC yet so so far its been cool when I asked it to be.
    Stage 2+ 2015 Audi A3 2.0T Prestige
    My Build Thread
    @EUROGRADE_
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    Common issues on the S3. My A/C compressor was replaced within 1 week of ownership
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Oct 19 2013
    Saint James ny
    Hopefully it doesn't take that long to order it. Sounds like that's the problem. Just pulled the Neuspeed module out today, cars going in for service Tuesday. Thanks for the heads up, I'm also getting that sensor checked the passenger air bag. It's annoying as hell.
    Senior Member Two Rings soulflyer's Avatar
    Apr 06 2015
    Ottawa, Canada
    If our cars use the same technology (constant turning compressor with a RCV that controls the load of ac) as I had in my 2010 Golf TDI then were in for a ride with the a/c...
    here some reading.. http://forums.tdiclub.com/showthread...errerid=138314
    2018 S3 Technik, Ara blue
    SOLD 2015 S3 Technik, Sepang blue
    I have VCDS, will do scans and coding for beer in the Ottawa ON, area. PM me.
    Oct 19 2013
    Saint James ny
    Ok so on my way in to work today it just started working again. Ugg I wish it stayed not working, now they'll say there's no problem like last time. Hope it goes out again before Tuesday
    Aug 29 2014
    NY/LA
    Quote Originally Posted by Surf2602 View Post
    Which dealership did you go too? Smithtown Audi?
    My Build Thread
    @EUROGRADE_
    Oct 19 2013
    Saint James ny
    Yes
    Jan 22 2015
    Mississippi
    My dealership came back and told me at the time that nothing was wrong. I insisted they take another look at it and after an hour they came back and said that it was needing to be rebuilt at first then later said it will be replaced.
    Oct 19 2013
    Saint James ny
    The compressor?
    Aug 29 2014
    NY/LA
    Yes
    If you want a second opinion so to Atlantic Audi and have Sean look at your car. Hes a good friend of mine and is one of there techs
    My Build Thread
    @EUROGRADE_
    Oct 19 2013
    Saint James ny
    Ok thanks, I've only dealt with smithtown audi with my last car. They flagged me td1 My fault for not flashing back to stock. Car was a lemon. I stopped in yesterday and they said if I have a loaner just bring it in and they will check fault codes. Will see. I'll try atlantic next. He mentioned they have replaced compressors on a3's but they replace it with the same one. That's like gm with harmonic balances that are defective, they swap for like which doesn't make sense cuz they fail again
    Oct 19 2013
    Saint James ny
    Just got the call back from Audi no fault codes and they cannot find any problems, I just have to bring it back when it happens and not wait
    Oct 19 2013
    Saint James ny
    On a brighter note,I removed the Neuspeed module. No detection, gotta admit I was a little nervous about it.
    Oct 19 2013
    Saint James ny
    Well it happened again, so I brought it in yesterday again, a different tech found a tsb on a faulty valve the other tech missed. It was replaced, seems to be working fine now. Will see when it warms up again.
    Mar 06 2016
    LI/NY
    Surf2602,
    did they provide you with the TSB number, and the name and/or part number of the defective valve ???
    What was the description of the work completed on your work order receipt ???
    all the best.
    Thanx,
    Russ
    Aug 29 2014
    NY/LA
    Was it the same N280 valve that was replaced on mine?
    My Build Thread
    @EUROGRADE_
    Oct 19 2013
    Saint James ny
    I didn't receive the paperwork yet, I'm sure I'll get it today. Once I do I'll let you know
    Oct 19 2013
    Saint James ny
    It was the n280 valve they replaced. Part# 5q0260839a
    Mar 06 2016
    LI/NY
    thanks for the info.
