Just had a rear brake line failure, my fault.
When replacing rear pads, as you remove the caliper you may tug slightly on the brake line. This can pull some line through the rubber locating grommet. When you replace the caliper, the section of line between the caliper and the grommet will now have some slack. I swap pads a lot (for track days) so I think a little more line got pulled through each time eventually causing a significant bow in the line. If you're unlucky like me, the bow may cause the line to come in contact with the wheel hub. See the result below.
When you replace your caliper, give the line (between the grommet and the hard line) a little tug to take out any slack between the grommet and the caliper. That section of line should be as straight as possible. There is no relative movement here so no need for any slack. All the slack should be between the grommet and the hard line. Could also pop the grommet out of its bracket before removing the caliper, but I found it quite difficult to get the grommet back into the bracket (StopTech lines and grommet, others may vary).
On another note, when this happened I had NO braking. Pedal went to the floor. Luckily, I was in my driveway just setting the pads against the rotors. I thought our cars (all cars?) had a dual braking circuit that should still provide braking to three wheels should something like this happen. Certainly didn't work in my case. Scary.
