Results 1 to 15 of 15
    Jun 21 2014
    2012 Grand Cherokee 5.7 L
    Santiago, Chile
    Exclamation Looking at a 2010 S4 auto with loud roar noise
    All,
    I am looking at a S4 auto with 70,000 km (44,000 miles) and the car looks really good and has several (not all) of its maintenance services done at the local dealer, but not the last couple. VIn is WAUZZZ8K3AA119788. I am located in Chile, South America. Roads here are not that great but not too bad, in general, but lots of speed bumps.
    It drives fine and I am really tempted, but has a loud roar noise .
    It has the OEM 18" wheels with Yokohama ADVAN NEOVA AD08 R, which is a summer performance tire. The tires still have quite a lot of thread life on them.
    It is in need of new brake pads and rotors, as the rear pads are extremelly thin and when depressing the brake pedal you can feel they are pretty rough (noise, pedal feeling).
    I am suspecting the roar is due to tire noise, but researching online it does not seems this tire is noisy, so I am not sure.
    The noise/roar happens at low speeds and does not seem to change when switching weight from side to side (turning right and left). It happens also even when moving in neutral at the parking lot at very low speed (under 10 mph). It also continues as speed increases. It happens when the brake pedal is not depressed, so unless the pads are engaging somehow all the time, it is not brakes, I don't think.
    The seller knows of it and I think I might be able to bargain the price down to cover a part of the tires cost, if I decide to move forward.
    What else could this be? I am thinking that unless both sides wheel bearings are bad (not likely?) it is not that.
    Could it be differential or transmission? Anyway to check that?
    Thanks for the help
    Jun 21 2014
    Santiago, Chile
    By the way, this is its configuration, just in case.
    PRCode: 0G7 = Tiptronic
    PRCode: 0JH = Weight category front axle weight range 8
    PRCode: 0YJ = Weight range 9 installation control only no requirement forecast
    PRCode: 1AT = Electronic stabilization program (ESP)
    PRCode: 1BD = Suspension/shock absorption for special sports design
    PRCode: 1KE = Disc brakes rear
    PRCode: 1LJ = Disc brakes front
    PRCode: 1N3 = Speed-related variable steering assist (Servotronic)
    PRCode: 1SB = Additional engine and transmission guard
    PRCode: 1XX = Leather trimmed multi-function sports steering wheel w/ Tiptronic
    PRCode: 2K3 = Reinforced bumpers
    PRCode: 3FE = Electric slide/tilt sunroof with sun screen/sunblind
    PRCode: 3L4 = Electric seat adjustment for both front seats driver's seat with memory system
    PRCode: 3NZ = Rear seat bench unsplit backrest split folding
    PRCode: 3Y2 = electrically operated roll-up sun screen for rear window
    PRCode: 4F2 = Central locking system Keyless Entry
    PRCode: 4GF = Windshield in heat-insulating glass
    PRCode: 4KC = Side and rear windows in heat-insulating glass
    PRCode: 4UF = Driver's and front passenger air bag with front passenger air bag deactivation
    PRCode: 4X3 = Side air bag front with curtain air bag
    PRCode: 5D4 = Carrier frequency 315 MHz without panic button
    PRCode: 5MZ = Decorative inserts stainless steel - fabric
    PRCode: 5RU = Right exterior mirror: convex (large viewing field)
    PRCode: 5SL = Left exterior mirror: aspherical
    PRCode: 6XL = Exterior mirrors: with memory function automatically dimming electrically foldable/adjustable/heated
    PRCode: 7A3 = CD player
    PRCode: 7K0 = Without tire pressure warning light
    PRCode: 7MG = Emission standard EU5
    PRCode: 7Q0 = Without navigation device
    PRCode: 7X4 = Park distance control front and rear
    PRCode: 8BP = Bi-functional headlight with gas discharge lamp
    PRCode: 8GR = Alternator 150 A
    PRCode: 8K2 = Daytime driving light mode for urban driving
    PRCode: 8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
    PRCode: 8Z5 = Not hot country
    PRCode: 9Q4 = Multi-function display/on-board computer with check control
    PRCode: C2R = Alloy wheels 8J x 18
    PRCode: D11 = 6-cyl. gasoline eng. 3.0 l/245 kW (24V) TFSI homogeneous Base engine is TC6/TE8
    PRCode: E0A = No special edition
    PRCode: F0A = No special purpose vehicle standard equipment
    PRCode: J1U = Battery 450 A (95 Ah)
    PRCode: N1U = Silk napa leather seat covering
    PRCode: Q4Q = Sports front seats
    PRCode: S4Y = Region
    PRCode: TC6 = 6-cylinder gasoline engine 3 L unit 06E.C
    PRCode: U1A = Instrument insert with km/h speedometer clock tachometer and trip odometer
    PRCode: X9T = National sales program South America
    Thanks
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    do you have a dealership where you can bring the car to have an inspection done?
    noisy tires are annoying but do not typically make a "loud roar" but if english is not your first language some thing may be getting lost in translation?
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    May 01 2014
    United States
    Could be a wheel bearing going bad. Just not enough to impact the way it drives yet.
    Something like this (minus the shaking): https://m.youtube.com/watch?v=QPf2ibWgBm8
    When I went from my super bald summer tires to my newer winter tires, it had a major increase in road noise it was almost disturbing.
    Jun 21 2014
    Santiago, Chile
    An inspection is definitely a good idea. I will do that, thank you.
    If I can get some hints to what this could be I can probably point it to the dealer for a more careful inspection. You know, I am not that confident in a dealer diagnostic.
    In reference to the noise , it sounds like bad wheel bearings, but does not change as I load each side, so I suspect it is not that. It could be tires, but would tires be loud enough that you can feel at a very slow speed? These are quite grippy.
    Thank you
    Jun 21 2014
    Santiago, Chile
    KurTech,
    Not exactly like that video, but, similar to this https://www.youtube.com/watch?v=UpsLaSzcAu4 (your link led me to that). BUT, no changes as I shift the weight from side to side, like in the video.
    Thanks
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    if i had to pick prob a wheel bearing
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    May 01 2014
    United States
    Do you notice any vibrations at all?
    I would think it's most likely wheel bearing, but it could also be a differential noise as well.
    I would make sure wherever you take it hears the noise and you ask them to take a look at the wheel bearings and check the differentials.
    I'm not super familiar with the center diff/Quattro system yet, but I've had rear differentials go out on other cars I've had that made a really bad noise as well.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Never buy used car that you have doubts about from the beginning .what else could be wrong. Certainly do not buy used car w/o a long warranty.I would pass
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Jun 21 2014
    Santiago, Chile
    There are no vibrations. I am surely taking for an inspection, before anything, if I decide to proceed.
    Thanks
    Aug 25 2008
    Boston, MA
    just an fyi, i just replaced an older set of conti DWS tires with the newer DWS 06 tires. after putting the new tires on the car the sound difference is night and day. it is so quiet now that it feels like totally different car. i thought i had a bearing issue but my dealer confirmed the bearings were fine when i did my 55k service. just another data point for you.
    the only bad thing is that since the car is so quiet now i now hear a couple more squeaks and rattles in the interior.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    if your driving and hear the noise at speed and you shift the trans into Neutral does the noise pitch change at all. if thats the case its either a wheel bearing or in the Diff. Does the noise change pitch if you push on the acell pedal and let off. If the noise is the same regardless of throttle input then its not a diff problem and more likely a wheel bearing issue
    Jun 21 2014
    Santiago, Chile
    UPDATE:
    Followed advice and took the car to the local Audi dealer. I rode with their technician while he drove to troubleshoot it.
    Noise did not change when riding in Neutral. Not as noticeable immediately after accelerating (when under lower load in front wheels) and increase under breaking. No significant change from side to side. Tech thinks it is front wheel bearings.
    I made an offer under the condition of have the noise resolved/fixed.
    Owner taking the car to the shop today and should know next week if all will work out.
    Thanks for the help
    Oct 20 2008
    Bloomfield Hills, MI
    Have the dealership swap wheels/tires with another car that for sure doesn't make noise and evaluate your car.
    If it goes away, you have your answer.
    E90 M3 6MT - Melbourne Red
    (Sold) 2013 S4 - Glacier White / Black
    Jun 21 2014
    Santiago, Chile
    Swapped tires with an S5 and noise was gone. Decided to buy the car and now I have a noisy tires S4. One more reason to drive it hard and wear these out, so I can put new ones in.
    Thanks
