Results 1 to 9 of 9
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Axle Grease got on wheels -- seems stained and wont come off -- suggestions?
    As my post implies, one of my axle shaft boot/bearings came undone and leaked grease all over the inside and outside of one of my wheels. The grease seems to have stained the painted wheel.
    Any suggestions for how to resolve this? The wheels are otherwise in great shape.
    May 12 2015
    NorCal
    What have you used and attempted to clean the wheels to date?
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    Pics to see
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    3m adhesive remover is pretty effective on most things and safe for paint, have not used it for this scenario however.
    Sep 24 2007
    Chicago
    Quote Originally Posted by FliGi7 View Post
    I've used soap & water, sponges, and the iron-out type of products that help remove the metal particles with my first try. Simple green to try to break up the grease on my second try. Nothing seems to have made it budge.
    Jun 19 2007
    02 A4 3.0 Avant
    NY/FL
    Get some prepsol. That will get the job done.
    May 12 2015
    NorCal
    Without pictures, not sure how much help we can be. But, if you're certain it's just a grease stain that won't come off, you can try the following in increasing order of aggressiveness (and thus, caution):
    White vinegar
    Rubbing Alcohol
    All-Purpose Cleaner (recommend Meguiar's for OTC availability and cost)
    Clay bar
    Meguiar's #105 polish with a microfiber and elbow grease (no pun intended)
    All should be safe for a painted wheel, so long as you don't let it dwell too long or dry on there AND you properly protect the surface thereafter. OTC Meguiar's #21 Sealant and/or Nu-Finish is super cheap and provides decent protection.
    Veteran Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    Quote Originally Posted by Lugi20 View Post
    Try some dishsoap like Dawn or Palmolive to get all of the stuff off and then use some metal polish.
    Are the wheels, painted, coated, aluminum, chrome?
    2007 Avus Silver Rs4
    Bone Stock
    Sep 24 2007
    Chicago
    Quote Originally Posted by Avus RS4 View Post
    They are silver OZ Ultrallegera's, which I believe are painted with a clear coat.
    I'll try to get pictures up so you all can see what I'm talking about.
