Originally Posted by
icanfly
Have you opened the ECU box to see if something got wet?
There are several fuzes/wire connections etc in the ECU box. If you have a bad seal on the ECU box and it's getting wet and or moisture in there, you can be causing a short in the system. What you are talking about doesn't sound like the "Alternator/Battery" problem because you'd get some indication of a warning. If the car works and then doesn't and then does and then doesn't... without symptoms of slow to start or low level lighting etc. Then you are having an electrical issue. I had a similar issue when the secondary board of my ECU came of the main board - resulting in a "ran fine when I pulled into the parking lot, but now wont start/click/anything - totally dead".
Check out
Joeys motor pull DIY Specifically Phase 5 where he shows the removal of the engine harness stuff... skip all that and just pay attention to the "opening the ECU Box" and pulling the guts out part. Be extra careful when you pull the lid that you don't bust the back corner of the lid off (like my effing original mechanic did... thanks duush!). you'll want to use a super small ratchet to get to the back bolts. Take your time and go slow.
This will let you see the state of the ECU, the harness and connectors and the fuse block that sits in that box. Ultimately this will either validate or rule out any "wet ecu/wiring" problems you might have. Further, I'd suggest this route as you mention that it started after the carwash.
good luck
x3
It may be possible that it's a battery issue as the ECU has a threshold voltage it needs to function.
However, as someone who's bricked a few ECU's while learning to tune Motronic, your scenario (turning over with no communication) is exactly what happens when you have an ECU issue.
Look at it this way, you've wasted anywhere from $150-600 on getting those useless tits at the dealership to tell you what you already know, plus how many hours of your time bringing the car to and from different shops, why not take the 30 min, pull the ECU and have a look to make sure you don't have a short.
As well if your ECU has been compromised, I might suggest making a bench flasher and backing up your EEPROM and immobilizer data in case your ECU takes a complete dump on you. (easy to do with an ebay VAG-COM cable and free software from Nefmoto.com)
Bear in mind that if you completely loose your immo data, you're going to have to get the dealership to recode your cluster to any replacement ECU that you buy. However, you can buy a replacement ECU for $100 and clone it, so I highly recommend getting that data backed up ASAP.
