Well I have started to notice vibrations and kind of like a clanking noise. The noise happens not when im accelerating, but as soon as I left of the throttle it makes the noise and vibrations. The noise/vibration goes away once I depress the clutch or when I pop it out of gear. I also noticed that it makes a little bit of noise when Im sitting still and with the car in neutral and rev it up. I recently replaced both front cv axles, one rear cv axle, and the driveshaft. All cv axles still have no play, torn boots, or anything. I then replaced my snub mount with a polyurethane one, and with no avail nothings changed. I then checked my transmission mounts and motor mounts and all are good. about 10k miles ago the clutch was replaced, but the OEM Dual Mass flywheel was not. All bearings were replaced also along with the clutch. Ive been trying to search but it seems like no one else has the same symptoms as me. The car has 150k on the clock. Any help would be greatly appreciated!
