Results 1 to 40 of 55
    Sep 10 2015
    VA
    Lowering links and vagcom lowering
    Can these be run side by side and are their any negatives if doing so. Does the car still adjust in height when going from dynamic to comfort and also will it raise too?
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Don't you have an A6? VAGCOM lowering doesn't apply to the A6, at least not in the US.
    Established Member Two Rings turbello18's Avatar
    Nov 12 2010
    08 Q7 Sline
    Manchester
    Believe you need bags for links too.
    '13 S6
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    i would like to know too ttt
    '23 Tesla Model X | '17 Ducati Supersport S
    Dec 20 2006
    CAN
    I use both, no issues, works great.
    Mar 04 2015
    Houston, TX
    Quote Originally Posted by CanuckRS View Post
    What was your total drop on both? Curious as I hadn't seen anyone use both links and Vagcom
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by tph4m86 View Post
    On my previous S6 I used links and vag. With the links you can go as low as you want pretty much. I just lowered it an additional inch beyond the 17mm on the vag. Tire was at the top of the wheel arch, couldnt get a finger in.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Dec 20 2006
    CAN
    you should be using vagcom with links imo to tweak the height. links can get you close to being equal all around, but it's much easier to use vagcom to get the perfect height after the macro adjustment with links.
    i don't recall the total drop, you can go as low as you want using both methods. the only limit will be rubbing which is what happened to me so i raised it up a bit more.
    emilyPay.com - Revolutionizing payment processing by making transactions simple, secure, and more reasonably priced.
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    can the links be installed without pulling the wheels or using a lift? im between the links and a lowering module that allows real time raising and lowering from the iphone beyond what the H&R and KW units can do
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Sep 28 2009
    suburb
    i just did vag com. i couldn't go 17 mm for some reason :( only 14 mm. anyhow, 14 mm on my car gives you 1 finger width (about .75 inches) of wheel gap. HTH someone.
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Dec 20 2006
    CAN
    Quote Originally Posted by richib86 View Post
    if you have a lift, probably? i just removed the wheels and did it that way, much easier imo. doing this links, you will get your hands dirty and it'll take 1-2 hours your first time fyi. if this doesn't appeal to you, get the module.
    Nov 05 2006
    Fair Lawn
    im all for getting dirty, im just too lazy to pull the wheels off and dont have a lift at home just a floor jack
    Oct 27 2015
    Latvia
    Just ordered this module, you can adjust the height with phone, no need to get your hands dirty and mess with vag-com. http://www.active-sound.eu/en/active...air-suspension
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Quote Originally Posted by audi12345678 View Post
    Looks like a very nice system. How much is it?
    For others, here's a video to watch while the Active Sound website is down:
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Nov 05 2006
    Fair Lawn
    This was the exact module I was referring to that I am looking into. I'm waiting on a response back on if they will ship to the US, no option for that on the website.
    Sep 10 2015
    VA
    Thanks fir the responses guys. Didn't get a chance to get back on here before install but they worked great. Currently running 28mm drop on links and 14mm on Vag-Com. It's perfect and makes the car way more mean. Not done my final asjustment with vag com but it's very close. Set them 5mm less than stick links.
    Sep 28 2009
    suburb
    Quote Originally Posted by Barritia View Post
    how can you go that low w/o rubbing? do you have a pic? i put spacers on and rub at 13 mm drop
    Audi SQ7
    Audi B8 S5 (gone)
    Aug 27 2015
    New Zealand
    How firm is the ride, when that low. You must feel every little bump, even in comfort mode.
    Sep 10 2015
    VA
    Feels the same which I'm surprised at. Only tried dynamic though so far. Will try comfort later today.
    I'm running 20mm spacers all round and no rubbing yet. Only done about 5miles yet though so we will see
    Aug 27 2015
    New Zealand
    Thanks. As far as I can tell, comfort mode seems to raise the car about 1/2 an inch (12mm).
    Sep 10 2015
    VA
    Used car for a bit and had one situation of rubbing but very light. Took the 14mm drop from vagcom and set it to stock so running 28mm until I get time to dial it in some more.
    Mar 04 2015
    Houston, TX
    Do you have any pics of it dropped 28mm on links as well as vagcom?
    Sep 10 2015
    VA
    Will grab you a couple later.
    I have had another issue though. I set air through VCDS to stock heights but I'm getting the air suspension error like I used to when I lowered 17mm on with VCDS. It looks like links also cause the same issue. Anyone experience this at all?
    Oct 27 2015
    Latvia
    Just installed this module, and everything works perfectly, I can control the cars height from mobile app, and the car drives much better, its agile and takes corners like coupe, Im very pleased.
    http://www.active-sound.eu/de/active...air-suspension
    Sep 10 2015
    VA
    I looked into that but couldn't find a US dealer. I hear that there's a module coming out where you can control the height through the MMI line you can on the Merc's. That would be sweet.
    Sep 10 2015
    VA
    Looks like the lowering links have got to come off. Even after setting car back to stock settings and adjusting the links to about 18mm drop I still get the air suspension error. Once I get the lowering links adjusted to 14mm which I had before with VCDS lowering no more error. It seems there something on the vehicle that don't like being lowered more than 14mm no matter what method you use.
    Senior Member Two Rings mwmaroney1's Avatar
    May 08 2012
    2014 S6
    Strange, mine works just fine with both.
    Sent from my HTC6525LVW using Audizine mobile app
    Dec 20 2006
    CAN
    yes, very odd. i had mine slammed on links/vcds, no errors at all.
    Mar 20 2004
    Lawrenceville, NJ
    I got an error when I messed with the links after I had lowered the car one time. I reset the car to the original height settings and then set it lower again after I was done fiddling.
    20 BMW R1250RS
    Sep 10 2015
    VA
    Quote Originally Posted by HyperM3 View Post
    More detail please. Not getting the order which you did the lowering. I'm wondering if putting the ordinal links back on then putting suspension back to stock settings then putting lowering links back on will fix the issue.
    Sep 10 2015
    VA
    Ok here's what I'm thinking. When you select the reference level option the suspension is adjusting itself to a reference level based on where the lowering links are set to. Using the lowering links is messing this up due to not being "stock" lengths. Looks like I'm gonna have to remove them put stock ones on then reset VCDS lowering to stock figures then put the lowering links on.
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Okay. This makes sense now. As my performance dealer was having a problem resetting/calibrating the air suspension. I had an error code and they couldn't recalibrate the suspension properly because I have lowering links on. Their comment was they had to "trick" the suspension into recalibrating. They did a good job in getting it back to its pre-error code level but the front is about half inch higher than back.
    I don't have my original lowering links so does anyone know what the height of the original lowering links are? I can tell my performance dealer for future calibration purposes.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Dec 20 2006
    CAN
    one important thing that took me awhile to figure out was that after installing lowering links, the ratio for adjusting with vcds changed.
    for each mm of change in vcds, i found there was a 2mm change in actual height. that worked for me, ymmv.
    Sep 10 2015
    VA
    Messed with it some more today. Adjustment is not as accurate as it seems. I took car into our warehouse that has dead flat floors. I measure the differences and adjusted through VCDS. I only changed the front left and it was 10mm lower than the rest. Adjusted it 10mm higher on VCDS and it stayed exactly the same even after a drive both times. The others also changed +\- 3-4mm and I didn't even mess with them ones. So don't get the idea that if front is out 5mm then adjusting 5mm will fix it because that's not how it seems to work. I'm guessing it's got as much as 10+mm of play in the settings because they are never the same height even after not messing with settings.
    Mar 20 2004
    Lawrenceville, NJ
    Sorry for the delayed response. What happened was I had lowered my car via the links first and then I lowered it via VAG. After a while I took the links off and put the stock links back on. Thats when it threw the code. Had to go in and set the numbers back to the way they were stock and then lower it again while on the oem links.
    Regarding people trying to adjust each corner to make them the same height, I wouldnt do that. Theres a reason the computer adjusts all the time, its to compensate for something. If you set all the corners equal, whenever you drive they will change again. Next time you stop and try to take a reading, they wont be equal again. If you keep adjusting them then it will throw something off. I would recommend just lowering each corner respectively to its own 15-17mm drop regardless of what the number was.
    20 BMW R1250RS
    Sep 10 2015
    VA
    When I change my wheels on gonna take the lowering links of them try and set numbers back to stock drive it the a bit then put lowering links back on and see what happens. Everything I tried so far still gives me suspension error.
    Should know in about a week
    Sep 10 2015
    VA
    Ok here's some tips so you guys don't have this issue.
    Most important is make sure you return to stick parameters on VCDS whilst on stock lowering links and absolutely do not return to reference level when on after market links.
    When the car gets put into reference level it bases it reference level from a specific point at which the suspension sets its self. The after market links throw this off and gives the car a inaccurate level to begin with so from then on after market links will throw an error even if they are within normal parameters. I was getting the suspension fault warning even with stock links and stocks VCDS after putting the stock ones back on so had to go through VCDS to reset again once stock links were back on.
    Pretty simple now I figured it out.
    May 08 2012
    2014 S6
    It must vary car to car because I have none of those issues and I adjusted my height after the links were on.
    Veteran Member Three Rings arrivalanche's Avatar
    Jun 08 2014
    Placentia, CA
    Just did the same yesterday but with a 17mm vag drop. Not as low as my A6 on adjustables, but looks nice. I might even go lower, but I didnt feel like pulling the rims off again.
    -AARON-
    2018 S4 Black Optic
    2017 S6 Black Optic - Sold
    2016 S6 Black Optic - Sold
    2014 A6 3.0T Black Optic - Sold
    2014 S4 3.0T Black Optic - Sold
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
    Jun 08 2014
    Placentia, CA
    Quote Originally Posted by mwmaroney1 View Post
    Same here. No error at all.
    -AARON-
    2018 S4 Black Optic
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
