Originally Posted by
GTRchop88
Is this ok?
The intake cam drive chain timing does not look right here. There is 16 links between the 1st link and the 16th link, but the 1/2 sprocket tooth offset specified past the exhaust timing marks, is instead divided between the timing mark alignment at the intake cam chain link #1, and the exhaust cam timing marks. All of the offset should be at the exhaust cam timing marks. The alignment of the timing marks and the 1st chain link and the intake cam timing marks must be vertically aligned with no offset at link number 1.
It doesn't matter witch direction the chain links are counted, as long as the 1/2 sprocket tooth offset exists at the exhaust cam timing marks.
As long as the cam timing marks are aligned, the intake cam timing with the chain links counted according to the red lines is correct.
