Results 1 to 10 of 10
    Veteran Member Four Rings e.Mills's Avatar
    Aug 17 2007
    Park City, UT
    Community Diagnosis - stumped on 2011 Q5 2.0t with timing-related issues
    My wife's car has been going apeshit recently, and no idea what's causing the camshaft codes. I replaced all the coils, and spark plugs, to get the misfires to stop.
    Dealership diagnosed as needing a new camshaft sensor. Checked and ran the camshaft sensor on another 2.0t engine, and it ran fine for 50 miles with zero codes thrown. Still has a hard time turning over every 3rd or 4th start. Completely random.
    Any ideas on what to check next?
    Codes:
    Address 01: Engine (0-----CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8R0 907 115 P HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H17 0002
    Revision: E1H17---
    Coding: 0121010A290F0160
    Shop #: WSC 58755 001 1048576
    ASAM Dataset: EV_ECM20TFS0118R0907115P 001002
    ROD: EV_ECM20TFS0118R0907115P.rod
    VCID: 41897732D065FB363E-8015
    7 Faults Found:
    2796 - Camshaft Positioner (Bank 1 Intake)
    P000A 00 [096] - Slow Response
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 141624 km
    Date: 2016.02.22
    Time: 07:49:15
    4113 - Camshaft Position Sensor (G40)
    P0341 00 [096] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 141071 km
    Date: 2016.02.14
    Time: 15:22:48
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 00 [104] - Incorrect Correlation
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 49
    Mileage: 141005 km
    Date: 2016.02.13
    Time: 12:27:31
    4054 - Cylinder 1
    P0301 00 [237] - Misfire Detected
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 141776 km
    Date: 2016.02.23
    Time: 18:40:31
    4057 - Cylinder 2
    P0302 00 [236] - Misfire Detected
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 141776 km
    Date: 2016.02.23
    Time: 18:40:31
    7960 - Cylinder Disabling
    P130A 00 [040] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 141799 km
    Date: 2016.02.24
    Time: 07:55:26
    4051 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [237] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 141776 km
    Date: 2016.02.23
    Time: 18:40:31
    Readiness: 0000 0000
    Utah drivers.
    Aug 28 2013
    belleville nj
    Im having the same problem still working on resolving it
    @carbon_cleaning
    Jul 25 2015
    West Michigan
    Possible camshaft positioner problem. I've heard they can fail. I'm not sure how to test it tho.
    Aug 17 2007
    Park City, UT
    Quote Originally Posted by Aufenbahn View Post
    i had the camshaft position sensor pulled, put into another 2.0t car, and it ran fine without causing any errors. is that the part you're thinking?
    Utah drivers.
    Aug 17 2007
    Park City, UT
    bump. really confused on this thing.
    Utah drivers.
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    I have a used cps if you guys want, pulled from my car before I realized my tensioner went and was causing my issues/codes not fault cps
    Aug 17 2007
    Park City, UT
    bump.
    still having problems with these codes:
    Freeze Frame:
    Freeze Frame:
    Utah drivers.
    Aug 17 2007
    Park City, UT
    updated codes pulled. wow.
    Revision: E1H17---
    VCID: 41897732D065FB3631-8015
    10 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [040] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 148295 km
    Date: 2016.05.31
    Time: 07:51:20
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 148356 km
    Date: 2016.05.31
    Time: 16:43:56
    10540 - Camshaft Adj. Bank 1 Intake
    P052A 00 [104] - Cold-Start Timing not Reached
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 11
    Mileage: 148295 km
    Date: 2016.05.31
    Time: 07:50:25
    P000A 00 [109] - Slow Response
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 14
    Mileage: 147655 km
    Date: 2016.05.20
    Time: 17:58:31
    2795 - Bank 1: Camshaft A (Intake)
    P0011 00 [104] - Retard Setpoint not Reached (Over-Advanced)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 148110 km
    Date: 2016.05.26
    Time: 16:38:23
    P0341 00 [032] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 148690 km
    Date: 2016.06.04
    Time: 16:50:41
    P0016 00 [236] - Incorrect Correlation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 143
    Mileage: 147654 km
    Date: 2016.05.20
    Time: 13:02:11
    5671 - Boost Pressure Regulation
    P0299 00 [096] - Control Range Not Reached
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 149248 km
    Date: 2016.06.09
    Time: 08:53:55
    2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 00 [096] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 148295 km
    Date: 2016.05.31
    Time: 07:51:19
    4105 - Bank 1; System too Lean at Idle
    P2187 00 [236] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 149272 km
    Date: 2016.06.09
    Time: 13:16:02
    Utah drivers.
    Aug 17 2007
    Park City, UT
    For anyone still following along, we had a couple of issues. Dealt with all of them.
    - Stage 2 oil consumption. Replaced pistons, rings.
    - clip on the turbo wastegate to keep it open
    - replace camshaft, bank 1
    - replace spark plugs
    - replace coil packs
    did not replace the camshaft position sensor, nor did i do anything with the crank sensor. running like a champ.
    Utah drivers.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Check the camshaft position adjustor solenoid (sits on the front of the intake cam, the thing with the electrical connector on the front of the black plastic upper timing chain cover. Sometimes it is the oil-control plunger that is behind the adjustor solenoid, called the "3/4 Valve" (or maybe "3/4 Actuator".....not sure). These sometimes stick and then the Intake Cam adjustment does not respond correctly, and the computer flags this as one of the DTCs you have. These can get stickey if you don't change the oil often enough.
