Results 1 to 7 of 7
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Has anyone replaced an axle seal on the rear "smart" diff?
    I'm debating on doing this myself and couldn't find anyone who did it their self by searching. Noticed my rear diff was seeping oil near the passenger side axle input shaft last night, so who knows how long its been leaking. Is it as simple as unbolting the rear axle and sliding out the input shaft or as hard as dropping the rear subframe? I'm a little leery on doing it myself because an Audi mechanic told me audi axle seals are finicky and can continue to leak after you replace them. I also see this is a common problem on 2010/2011 cars.
    PS: I've also got an extra bottle of Royal Purple 75-90 laying around, will the smart diff be happy with that? Thank you
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Jul 05 2014
    Houston
    Well I went to change the fluid tonight and when I took out the fill plug fluid started dribbling out. Meaning the diff was full! Upon closer inspection of what I thought was seeping could be axle grease.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by fitzydude View Post
    Most likely it is from the axel if you don't see a significant amount of fluid (like drops on the ground). My 2012 with 23k miles definitely has some minor seepage from the inner boots closet to the diff, but nothing from the diff itself.
    Both the dealer, and shop I go to didn't think it was a big deal now. They did say it's something I'll need to address down the road, but probably not for a while. I also got the impression that removing and replacing the rear axels is not an easy strait forward process. The tech I talked to (who's retired, but trained a lot of the local Audi techs) said it would take him 8 hours or an all day type of job.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jul 05 2014
    Houston
    Thanks for the response. I've been getting the impression it's more difficult than it sounds too. I'm going to have it at Zinks next week to have some work done, I'll have them look it over then. I can't believe your only at 23k!
    Established Member Two Rings ZGskibum's Avatar
    Jan 17 2016
    Aspen, CO
    This:
    http://www.audizine.com/forum/showth...wn-Issue/page5
    Start reading at p. 5, about 3/4 of the way down, where the link to the TSB is posted. In summary, the problem is a defective seal in the cv axels. Under spirited driving, the oil component of the cv grease separates and dribbles out through the faulty seal. The cv axels will eventually fail, but in more a "long tortuous complaining decline that you're all-too aware of" sort of way than a "sudden catastrophic surprise failure" situation. To fix it, you either replace the axles (parts $$$$ labor $$$) or disassemble then reconstruct the axels with proper seals and new aluminum bolts (parts $ labor $$$$$, plus high probability of breakage during disassembly resulting in need to order parts from Germany). Either way, you have to drop the exhaust and sport diff to get the axels out.
    2011 S4 6MT Sport Diff | Ibis w/ Black Optics
    APR Stg II+ | AMS Cooling | AWE Touring - Res DPs | Roc Euro Intake | Sachs X-Tend Clutch w/ USP SS Line & Lutz (OEM) FW | Stoptech ST-60 355 BBK w/ SS Lines | H&R OE Springs | Bilstein B8 Shocks/Struts | CR-15 | H&R Rear Sway | Alu Kreuz | 034 Trans/Engine/Diff./Strut Mounts | BC Forged EH 307 19x9 ET 40 (Summer - Michelin PS4) | VMR V810 19x9.5 ET 40 (Winter - Pirelli Sottozero) | ECS Shortshifter | P3
    Jul 05 2014
    Houston
    Yikes! Well it sounds like I'll be playing the waiting game on this one. I'm still surprised those axles arent easier to remove.
    Jan 09 2008
    SF Bay Area
    I'm getting the rear cv joints re sealed soon on my 2010 B8 S4. As for a lot of things on this car the parts are relatively cheap ($100-130) but it is quite labor intensive, ~5 hours. I too had been told/thought it was the rear diff leaking, but it seems like it is the cv boots. I might as about getting them replaced as well... just in case.
