I have a 2008 A4 with a 2.0t and have noticed a lot of gas in my oil. When I first noticed it it didn't seem that bad, but I decided to look into why it was happening. I only have a VW dealership in my town so I took my car there to ask them what this was all about. I was told the PCV was a common issue and possibly had a recall. They directed me to an Audi dealership about 75 miles away, which I ended up taking the car to, to get the PCV and fuel pressure sensor replaced with the update/recall. After I brought my car back home I decided to change my oil. The oil seemed very unusual and after I drained the oil I noticed about 8 quarts of oil/gas came out. Everyone I had talked to said that my issue is more than likely the PCV and to just change the oil and keep an eye on it. I changed the oil and have driven it maybe about 250 miles and already the dipstick is reading that there is a quart more fluid since I filled the oil. My check engine light was showing, P0036 HO2S heater control circuit(bank 1 sensor 2), P0089 suction control valve stuck, P0301 cylinder 1 misfire detected, P2293 fuel pressure regular 2 performance pending. It was showing all of these codes before I got the PCV and fuel pressure sensor replaced. I haven't scanned it since. I have been told that it is common to get fuel past the cylinder rings, but my concern is something has to be wrong with this much fuel in the oil. Before this issue started I started having a rough idle at cold start. The rough idle doesn't stop when the engine gets up to temp, but it stops after the car has ran for about 1-2 minutes, then it will get up to temp a few minutes after that. Sometimes it will backfire while driving after I let off the throttle, but that is the only time it backfires. Recently when I start the car It wont hold an idle unless i keep my foot on the throttle and try to average 2,000 rpms(which is very difficult to do because it will get to the point it tries to die, then it will rev up to about 3,000 rpms and back and forth). After managing the throttle for a couple minutes it becomes less severe and will idle rough for a couple minutes then it's fine and can be driven. However I don't want to drive it at all until i get this issue resolved. Any help is appreciated, Thanks.
