Originally Posted by
bmwpower603
Is there an easy solution to fitting the mechanical adjuster on while I'm trying to fight the chain on? I can see why you didn't seed it all the way.
Maybe I can seed, and tighten the adjuster. And then put the chains on?
in order to get the chain back on you have to have your adjusters that you push the shims into, collapsed all the way (with the drill bit poked into the hole keep it mechanically collapsed - if they are new, they should already have those little pins in them keeping them collapsed) to allow for slack in the system. First, I started with the chain draped over the mechanical adjuster / cam sprocket and lower sprocket with the mechanical adjust fully seated and the bolt in it but just finger tight to keep it from moving around. Then I very very carefully worked the chain over the collapsed guide tensioner using a pick tool and ultra thin flathead to carefully work it up and over the lip of the plastic guide...
TAKE YOUR TIME. Don't get frustrated and force it... this is the most important thing I can tell you. It's like a horrible rubix cube of suffering, but you'll get it figured out. the most important part is keep that electrical adjuster safe. You can get a bit forceful with the guides and be ok.
If anything, use the cam sprocket as the "loosen bolt a bit more in order to get more slack in the system" to get it all back together. Don't do that with the mechanical adjuster.
