Results 1 to 20 of 20
    Senior Member Two Rings a4ced's Avatar
    Mar 07 2016
    Lehigh Valley PA
    P0299 back after GFB DV+ install
    Hey guys,
    Went through a couple of other threads on this and saw the next couple of things to look at are the MAF and Wastegate. Before I spend any time guessing between the two I have a few extra symptoms. I also am losing coolant at a slow rate (throw some in reservoir every 2 weeks or so). No coolant in the oil or anything. Also I've noticed with the new DV+ installed I'm getting the code back more frequently. Could this point to the wastegate/turbo? Seeing as the DV+ holds boost pressure better than stock could this be throwing a more frequent code for that?
    Sent from my SM-G928P using Audizine mobile app
    Jun 17 2013
    jersey city nj
    Ive some threads about the GFB DV+ throwing a soft code for it. I think they the original spring from the stock DV to eliminate that code from coming back
    Id the coolant flange at the back of the cylinder head for signs of leakage. Its a common failure in the 2.0T's
    Mar 07 2016
    Lehigh Valley PA
    That was just replaced also... I don't have the stock DV anymore to try as it was shot anyway
    Dec 01 2014
    idaho
    It is my understanding that you have to use this with a stock diverter valve. Just making sure you did this. Since your latest post made it seem like you didnt...
    Mar 07 2016
    Lehigh Valley PA
    Yes you have to separate the DV then install these components. That is done
    Mar 07 2016
    Lehigh Valley PA
    Could a bad N75 cause this?
    Jun 17 2013
    jersey city nj
    Your gonna have to Vag-com this to get the actual data instead of a generic code reader
    Account Terminated Four Rings
    Oct 15 2013
    that code is low boost pressure right? try replacing the air filter. if the code comes back it could be a waste gate issue.
    Oct 24 2015
    Perth, WA
    You definitely plugged in the solenoid loom after install?
    My respray thread
    Dec 01 2014
    idaho
    I got that code several time. Pulled my dv off and it had exploded. Came out in three pieces. Replaced that and the car has been happy
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    IIRC, that's an under boost code. I would be checking the waste gate for play.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    It happens because the computer isnt used to the snappiness of the diverter valve and noting "that something isnt normal." If you remove the top spring the gfb will act as a normal dv and the code will go away, but wont hold boost as well as before. Im assuming the car isnt going limp mode ?
    Oct 24 2015
    Perth, WA
    It will hold boost exactly the same, gfb says that, and I got no code.
    That code is overboost I'm sure
    Established Member Two Rings blackbowtie's Avatar
    Mar 30 2014
    07' A4 S-Line 2.0 6M
    NE Ohio
    Quote Originally Posted by Okedokey View Post
    Underboost
    Quartz 07 A4 2.0 6M S-Line
    Mar 07 2016
    Lehigh Valley PA
    I think I need to invest time into the wastegate, it is definitely underboost and it seems that the boost is actually fluctuating and then dropping off to about 9psi. Same symptoms before and after the DV was replaced, the DV+ shouldve done something at least for the fluctuation and drop off. And yes the DV+ is definitely in correctly. Going to replace the air filter cause i need to anyway before anything crazy. I guess if its the wastegate we'll be going K04 sooner than later
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by a4ced View Post
    Waste gate is pretty easy to check. Just grab it and see if it has any play. It should be snug and not move when you push it side to side. If you were up looking at the DV, you were almost there. Just make sure the engine is cold, obviously.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by blackbowtie View Post
    Underboost
    Sorry my bad, i was thinking of a similar but different thread. It was 2am ;o
    From rosstech
    Possible Causes
    Hoses/Pipes incorrect connected, disconnected or leaking
    Charger Pressure Control defective
    Turbocharger faulty
    Diverter Valve faulty
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check / Clean / Replace Charge Pressure Control
    Check Turbocharger
    Check Diverter Valve
    My respray thread
    Mar 07 2016
    Lehigh Valley PA
    Quote Originally Posted by JDillon15 View Post
    Definitely some noticeable play in the waste gate. I guess now is as good a time as any for a K04
    Jul 11 2014
    Chicago, IL
    If you need to get by, used turbos come up from time to time for ~$200. Otherwise, JHM just released their stage 3 kit for $4000. I'm not 100% sure of the cost for a K04, but after tuning, fueling ect, you might be close.
    Mar 07 2016
    Lehigh Valley PA
    I actually am stage 1+ through Unitronic. Initially I was going to go to stage 2+ come summer all this really does is speed that up, I'm half way there with components (S3 injectors on the way as well as FMIC.) The Stasis system is here already and the down pipe and test pipe on the way. Soon Ill order the K04 and JHM HPFP kit and just go all the way. I'm really happy with Unitronic for now and the shop that does it is extremely local lol plus 150 for the upgrade since I am already tuned through them.
