It's unlikely that it would be the head gasket
http://www.audizine.com/forum/showth...=1#post4049232
Are you always checking when the engine is hot? If you check it when it's hot, then again when it's cold, you will most likely get two different levels. As long as it's always above the min line, I wouldn't lose any sleep.
Otherwise, on the passenger side, between the air box and headlight is a series of hoses, there is a plastic elbow in there that may crack with age. Other than that, if you want to get under the car, remove the belly pan then look around the alternator, water pump, and aux radiators. If your feet are wet you could investigate the heater as well.
