Results 1 to 22 of 22
    Jan 03 2016
    Myrtle Beach, Sc
    Lightbulb Bluetooth streaming!!!
    I know there are tons of articles. I first bought the A2DP and it works well but it doesn't push the audio information to the screen such as what is playing say for instance on pandora.. I did come across one that does do that. Does anyone know which one it is???? I cant seem to find it anymore.
    Nov 30 2010
    San Diego
    I'd be interested in knowing what product does this myself...
    Jan 03 2016
    Myrtle Beach, Sc
    I have a 2012 S4 BTW
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    I use a tune2air but song titles with Pandora are very glitchy.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jan 03 2016
    Myrtle Beach, Sc
    what about the track listing from your iphone?? how is that?
    Nov 23 2014
    North Carolina
    per T2Air information, which means take it with a grain of salt, any music played through an iphone should work with the stock controls in the car and should push through information. on an iphone using pandora, i am not sure, but the controls should still work. on anything BUT an apple product it should still play but probably will not show information and probably will be problematic using stock controls.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by jsh139 View Post
    Tune2Air WMA3000A shows Pandora song info.
    http://www.amazon.com/gp/product/B00...ilpage_o08_s00
    This is what I use for bluetooth audio. While I don't use pandora, or any other streaming service to test it, I do listen to the music downloaded to my phone everyday and it transfers the information perfectly. Steering wheel controls and MMI controls near the shifter also work perfectly.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I had the original A2DP for Audi setup in my car, but the Belkin bluetooth receiver that came with it made the audio output very "tinny". I purchased a new Belkin HD bluetooth receiver from Amazon and the sound is fantastic now.
    One issue streaming from my iPhone 6. If I have the phone connected to both the car and the bluetooth receiver, then the audio will skip pretty regularly. If I disconnect it from the car and leave it only connected to the bluetooth adapter, then it streams perfectly and doesn't skip at all. I've tried 3 different bluetooth receivers and they all do the same thing, so I've eliminated that as the issue. I even got Apple to replace my phone. New phone does the same thing. Anyone else have this issue??
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by Vogz View Post
    Yep its been well documented on here that many others have that same exact issue. I can't believe you went to such great lengths over that. Would have been easier to search
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by DannyDeez View Post
    Search doesn't answer why. I was trying to figure out the cause.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    It seems like it's a problem with iPhones and the way they handle multiple bluetooth device connections. Many Android users don't experience the problem, so the signs point to the Apple hardware/software.
    Sep 11 2004
    16 Q5
    Westchester, NY
    It came up when I was doing my research before purchasing the tune2air. You would have had to read through the entire threads on the topic.
    Established Member Two Rings palmor's Avatar
    Apr 19 2011
    2011 Jeep Grand Cherokee
    MA
    Not just with iPhones, both my Samsung Note 4 and S6 Edge+ do the same exact thing. Otherwise with the a2dp4 it sounds great.
    One thing I do notice is that if I turn the car off for a short period of time (few minutes, like pumping gas) for some reason the adapter turns off and I have to unplug it and plug it back in. Almost like it goes to sleep but not long enough for it to come back on when I re-start the car.
    John
    Nov 25 2014
    Alabama
    Quote Originally Posted by infinkc
    Is this with an iPhone? My Tune2Air will only show PREV and NEXT in the MMI with my Android phone. Song titles never show, unless I'm in the wrong area in Media MMI. I'm in "Tracks". The standard forward and back buttons ( >>| and |<<) work fine too.
    2018 SQ5 | Monsoon Gray | Prestige
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by palmor View Post
    John
    Weird. I have a friend with an Android phone who doesn't have the skipping. Maybe it's hit and miss.
    Feb 18 2008
    LI, NY
    with this unit if I stream pandora through my samsung galaxy s5 will i still be able to receive phone calls etc from the phone incar or is it one or the other ??
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I have this unit for sale. Used for a month or so. if anyone wants it PM me.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    unfortunately, its the same case here for me, im an android user.
    I spoke with the guy from A2DP and he said "Another problem that can cause sound quality or connectivity issues
    is a specific Bluetooth software revision that shipped on a small
    number of Audi radios that doesn't conform to the published Bluetooth
    spec for device concurrency. In this case, the radio keeps
    "spamming" acknowledgement requests to the paired handset, even when
    idle, preventing the handset from always responding or sending audio
    data to other paired devices (the receiver in this case) on time."
    in fact, when i did unpair it from the MMI, the bluetooth stream worked fine.
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by EuroBeast View Post
    Yup, assuming the S5 supports multiple Bluetooth connections. The Tune2Air plugs into the AMI port in the glovebox and basically tricks the MMI into thinking you have an iPod connected. The Bluetooth phone connection is totally separate.
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Quote Originally Posted by schirm View Post
    Pm sent
    Veteran Member Four Rings TMurt's Avatar
    Feb 01 2011
    Indianapolis, IN
    From what I have read, the skipping issue is caused by the bluetooth connections (MMI and Tune 2 air, etc) fighting each other for priority. Only way around the issue is to disconnect from MMI. I also have an issue where the MMI system tries to default to my Iphone music every time I start up spotify. Not a big deal now that I am used to it, but what is annoying is that anytime I seem to switch stations on my sirius xm app or hit any button on it really, it goes back into my Iphone music. Apparently you also need to have at least one song loaded onto your music app or else the car doesn't recognize the device when you try to connect. Overall, there are a lot of issues with it that can't be avoided based on how the MMI system works and how the iPhone is programmed.
    Current: 2010 Imola S4 Prestige 6MT
    Past: 2007 Audi A4 3.2 Quattro
