Results 1 to 9 of 9
    Established Member Two Rings Adubinetsky's Avatar
    Jul 31 2015
    25quattro 2006 Audi s4
    Sacramento Ca
    b7 s4 wont go into gear
    when the car is off it goes through the gears, but once its started it wont go into gear. if i put the car into gear and start it it rolls and goes into gear. is the flywheel stuck to clutch? bad clutch? slave cylinder seems ok. anybody have this issue?
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    The SAC/Self-Adjusting Clutch mechanism of the pressure plate has ratcheted itself all the way down. You need a new clutch disc, pressure plate, pressure plate bolts, and throw-out bearing.
    Highly recommend getting a JHM lightweight flywheel and 1R clutch kit.
    Senior Member Two Rings icanfly's Avatar
    Jan 12 2012
    06 B7 S4 | 92 Corrado SLC VR6 | STI Powered HandBuilt TarmacRallyCar | Skydiving Rig
    Looking for a canyon to carve.
    Agree with JimmyBones, just installed mine and LOVE IT!!!
    Might consider doing several other things while you have it out - can you twist your own wrenches?
    slow is fast...
    Jul 31 2015
    Sacramento Ca
    Quote Originally Posted by icanfly View Post
    i do the simple stuff on my own, but dont know about taking out the motor and tranny.
    Jan 12 2012
    I just did it and can tell you that it's not as complicated as you think.
    you need an engine hoist, space to work and some time to dedicate.
    my first pull took 8 hours single handed.
    my second pull to me 2.5 hours from pulling into the garage to putting chains on the motor ready to pull it - again, single handed.
    I used Joeys DIY and it was simple as can be. Elsawin gave me all the torque info I needed.
    It only took a standard tool set and a few specialized tools (outlined in the DIY).
    JHM provides very good instructions for their LWFW/Clutch kit to install with. As long as you go slow, take your time and follow the directions to the letter, you'll do fine.
    I did full timing job and clutch job single handed.
    I had 1 hour of help getting the motor back into the car.
    everything else on my own.
    If you have the space, time and willingness... DO IT!
    PM with questions.
    slow is fast...
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    Link to the DIY writeup?
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
    Jul 31 2015
    Sacramento Ca
    PM with questions.
    I have been thinking about it.. It would save me a lot of money because i have to get the body fixed, I got her from a friend who's a dealer so I'm putting money into parts and fixing her up.
    Jul 31 2015
    Sacramento Ca
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by JimmyBones View Post
    x3
