I have a 2014 Audi S5 Estoril Blue.
I noticed a slight pull to the right few months ago and didnt bother much. Later i noticed my front passenger tire really getting worned out on the outer edge. The othe tires seems wearing normally. So i checked up the alignment and got feedback indicating it only needed small tweak.
Few days after that i still felt the pull, but now i was confused if the worn tire was causing the pull. So i finally ended up replacing all my tires for new ones.
I didnt perform alignment to check if the pull was reduced or went away (since my alignment was done about month before tire change).
I took it to another alignment place and they indicated my wheels are very close to alignment, however he indicated my caster is off and it cannot be adjusted. I looked back at my previous alignment and it said caster is fine. The Mechanic also said he couldnt remove the pull because it was due to the caster which cannot be adjusted.
Has anyone had this issue. I seriously want to know if its electronic steering alignment issue or some wheel misalignment issue. If i take it to dealership i know they will say alignment issue and i am sure i will end up with a pull and they will be like, this is normal and crap.
I am attaching a snap of the wheel alignment check (since i didnt do it).
curious to hear experiences from Audi owners.
