Hi guys, sort of new to the forum and Audi's in general (I am a die hard toyota 2jz guy... I know I know).
I have driven a couple cars with a 2.7t (allroad, b6 S4) and I decided it was time to get something AWD with a 2.7t and have some fun with it.
Some of you will probably remember Mec's B7 A4 with the built 2.0t, that he pulled out to do a 2.5 swap that was not completed.
After much debate I decided to scoop it up and start a 2.7t swap on it.
My brother has a b6 s4 avant with a 2.7t swap which gave me alot of the motivation for this project, and is very similar it turns out in terms of parts etc.. swapping into a b7 is much like a b6 which is nice.
At first it will be a stage 2 with stock turbo's just to make sure the motor and everything is healthy before I look into more power down the road (I gotta say the single turbo kit is quite interesting)
Threads are pretty worthless without pics, so I will start at the beginning with some pics.
day one I looked at the car, it had no engine in it.
To complete the swap, instead of getting every little thing separate I opted to find a whole A6 parts car, 2001 early motor and ecu but unfortunately from an automatic car, not a huge deal just a little more wiring.
really surprised after pulling everything I needed off that A6, I fit all of it and the engine into the back of my GX470, didn't even have to get the trailer =)
It took alot of research and I must thank the members here for posting up info related to the swap.
I got the engine and trans mated, along with the a6 heater core hoses and power steering line which are the main things you need to get hooked up before you drop the motor in as its a pain later.
Engine going in (took like 16 hours over 3 days, not working that fast but there were many complications including grinding through a torque converter cause those bolts stripped out in like 2 seconds)
being loaded onto the trailer as Mec and his buddy gave me a hand with dropping the motor in but I will be doing all the rest on my own (thanks again guys!! I owe you some wrench time)
going through university area back to my place to work on it.
I don't have any shots in the garage but I started knocking out little things one at a time, the list is rather long but I will get there.
so far the coolant hoses are hooked up and battery wire ran, still need to delete clutch fan, figure out why my 3.2l a/c bracket wouldn't bolt up, fuel filter and return line, alot of wiring, 3.2l core support, abs module, fan controller and all the little stuff...
should keep me busy for a while. questions, pointers, and positive comments are welcomed, hope to list any details I can here there were not covered in other threads to help others do the swap afterwards, and if/when I figure out the wiring I will post a diagram to follow.
Will post more updates and info once I get back to the wrenching =)
