Results 1 to 10 of 10
    Sep 14 2005
    NC
    Fuel pump replaced now gas gauge is a little off.
    Any idea on what could cause this??
    I'm going to take it back to the shop that did it so hopefully they will fix it
    Aug 24 2014
    Newport Beach, CA
    Did you make sure there isn't any interference with the fuel level sender on any of the fuel pump lines? Mine has this issue (albeit very slight) after I replaced the sender.
    2024 M3 Comp xDrive
    Sep 14 2005
    NC
    Is it tough to do?? Something I could do myself??
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    sender is probably off. mine does the same. only reads 3/4 when its full. just haven't had the time to pull it out and adjust lol.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by erykv1 View Post
    How do you go about adjusting it?
    2024 M3 Comp xDrive
    Jul 01 2014
    'murca
    I guess adjusting is the wrong term. Like you said, the float is most likely caught up on something.
    Sep 11 2009
    NE
    when you replace the pump you must pay attention so that no wires or lines are protruding beyond the basket as that will weight on the float or completely block it causing fuel level sender to report wrong level on the bottom of tank. there is more than one sender in the tank and they are daisy chained with wiring.
    Senior Member Two Rings BLK01S4's Avatar
    May 18 2004
    Miami BiSH!
    ^^ this . Had to reopen mine and correct it. I hate going in there PITA! Also helps to have the right tools for the job.
    Stage III Tip Mods "Stuff"
    Fastest Tiptronic ET: [email protected]
    Veteran Member Three Rings Kenrevo's Avatar
    Aug 05 2013
    MA
    Mine does the same thing. I've gone in 3 or 4 times now and have repositioned the wires each time, but it still happens, I'm thinking the top end of my sender is worn out.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    '01.5 S4 F21 on meth -- DD
    '05 Touareg V8, loaded
    '00 A4 1.8t Avant SOLD
    '99.5 A4 2.8l 30v QMS SOLD
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    They probably didn't align the basket in the correct orientation. The fuel basket has a notch (upside down triangle shape) in it that, you must align in order to avoid the gas gauge issue. And now the sending unit is hitting the hoses and wires and giving you a wrong reading in the gas gauge. Like others have stated you just need to adjust the hoses or basket. Here are some pictures for reference. The black arrow pointing at the notch should be installed next to the red arrow component.
