Results 1 to 7 of 7
    Established Member Two Rings fharper's Avatar
    Jan 23 2016
    Brooklyn, New York
    Possible head problems
    I have a 2003 A4 1.8T. I have a coolant leak coming from the head gasket. I was wondering if I should take this opportunity to upgrade cams while I have the head off trying to find the location of the coolant like. And if so what are some good options for cams. There is no other engine work done on the car as yet. I have had it for about a month and a half. Thank you for your input.
    Sent from my SM-N920T using Tapatalk
    Apr 07 2011
    If there's nothing wrong with the existing cams there's no need to change them.
    Jan 23 2016
    Brooklyn, New York
    I plan on building the engine so that's why I was wondering if I should upgrade the cams while the head is off.
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Depends what your plans are with the build. I'd wait til you decide what setup to go with before touching the cams.
    Audi Club Bay Area
    Jan 23 2016
    Brooklyn, New York
    Quote Originally Posted by Furly View Post
    Oh ok my plan is to make about 450hp
    Dec 19 2013
    Get the head leak tested as well. You could have just a blown gasket or you may have a crack or pin hole in the casting.
    450hp range check out the integrated engineering cams. They have a chart that shows what range the cams are for on their website.
    Audi Club Bay Area
    Jan 23 2016
    Brooklyn, New York
    Thanks for the info and I plan on going through the head with a fine tooth comb.
