[IMG]<iframe width="480" height="360" src="http://s989.photobucket.com/user/refueler15/embed/slideshow/2002"></iframe>[/IMG]The previous owner allowed the timing belt in this 2002 1.8 Audi A 4 to break. I have replaced the damaged cylinder head with an AWM head and a new head gasket. I also installed a new timing belt with associated pulleys, tensioner, and water pump. The car has a Spectra cold air intake, Podi boost gauge, a Borla stainless steel cat back exhaust system, new battery, new windshield, new clutch, an after market front mounted intercooler, new brake pads and rotors on both the front and rear. It has Toyo Garrit snow tires with about 90% tread left I've put a couple thousand miles on the car since I got it running to work out the kinks. I'm continuing to drive it as it runs and drives 100%. The car comes with the standard Audi Symphony stereo but has Bose speakers, the interior is black leather with 4 way heated front power seats, and the rear seats are heated as well. The previous owner also converted it from an automatic to a manual transmission I've got the back up lights and cruise control working. There are no engine fault codes and has a new Maine inspection sticker that is good until Jan. 2017. The original drivers side door had a big rust hole in it so I replaced it with a door that is not exactly the same color but is close and the trunk lid also had some rust issues and I used the trunk lid from the same donor car the door came from, the locks were changed in both door and trunk lid. The key fob locks and unlocks the car doors and trunk lid. There are several small cosmetic issues that could be fixed. The soft touch film on the instrument panel has peeled on several of the most used buttons/switches. The center arm rest top is broken and missing. The drivers seat has a crack in the seat bolster about 3" long that has opened up a little, the rest of the interior is in great condition, . The hood has more than the usual amount of rock chips which may explain the new windshield the previous owner installed. When its all said and done this is a very solid car it runs and drives great no rust, no rattles, and it is ready for a tune come take it for a drive.
