Results 1 to 21 of 21
Thread: Harsh Ride
    May 31 2011
    moore
    Harsh Ride
    The ride is getting a bit rough for my kid's sake, 10 months old, is there something I can install to get it a bit less bumpy? I'm running 18" Blizzak currently and will take it out in April everything is stock.
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    2022 Q7, 2018 Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    you could fit the ADS shocks into your system and VAG it into working. That would prolly offer the most comfort possible with the S4, otherwise, you are looking at aftermakret suspension, which will lower the car even at the highest setting and provide possibly a bumpier ride.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Simple fix. Take some air out of your tires. I run 39 PSi with the 19" tires front and rear. I would first try 36 psi and adjust down as low as 32 psi if necessary. HOWEVER, I have found the ride on my car to be very compliant especially as compared with the ride on 18" tires on my B6 S4. Also you don't want to switch to 19"wheels and tires because they will be less compliant than an 18"tire. FYI, you will get more tread wear with lower pressure. Back In the day, I had an 85 Corvette with the Z51 suspension. It was like driving a buckboard. Lowered the pressure and got a huge improvement . Actually got 15k miles on the OEM Gatorbacks. Replaced them with Dunlops and the ride was completely different. So the type and brand of tire can also affect the ride quality.
    Mar 01 2006
    Kitchener, ON
    If you are looking to maintain stock ride height, not sure how many miles you have on your current shocks, but the cheapest option :
    http://www.eurosporttuning.com/autop...pension=Shocks
    I have these but I am lowered. I don't have the manual handy but you can adjust them to the softest setting. Not sure how to compare it to stock though as I didn't go this route to compare.
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    What makes you think the ride is too harsh for your baby? I drove my infant around in a stage 2 A4 slammed on coilovers. He didn't seem to mind. It's the turns that makes them throw up. Lol
    2021 Audi S4, P34 Intake
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by Dr GP View Post
    I would advise against dropping the tire pressure from the manufacturer suggested rate. Especially going as low as 32PSI, you are asking for trouble, increased treadwear, decreased handling, etc.
    You are already on 18's so I would imagine you have a decent sidewall which is helping as much as it can.
    [CENTER]Scott
    2011 S4
    May 31 2011
    moore
    Roads around here are horrendous and unfortunately the little guy vomits if he's on the car for longer than 45 minutes. It feels like every small bumps are magnified and the struts are not shot, according to the dealership.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by hiwasss View Post
    I'm thinking that a slight change in comfort is not going to change that. My son threw up no matter what car we were in, or who was driving how. I think your money will better be spent on seat protection and cleaning products until he/she outgrows this phase. You can end up spending a lot of money on suspension, and likely, will still get puke in your car.
    Veteran Member Four Rings mojangles69's Avatar
    Jun 03 2013
    2022 BMW X3 M Comp / 2017 Porsche 911 S / 2008 Audi A6 3.2 Wagon / Magic Carpet / Camel / Donkey
    Charlotte / North Carolina
    http://www.askdrsears.com/news/sears...carsick-infant
    Try using benadryl before taking your baby out on drives longer than 30 minutes.
    This might also help, Neat 'n Cozy puking poncho! "It won't stop the puking...but it will stop the cleaning!"
    http://hyenacart.com/KidCozy/mt/2429/64047/Neat-n-Cozy
    2017 RS7 Performance - Sepang Blue - Performance Design Selection Package w/ Mercato Blue stitching and blue twill in interior carbon fiber components - APR Stage 2 w/ Militek downpipes and exhaust - Aquamist Methanol Kit - Custom Roc-Euro Intake - KW Adjustable coilover springs - K40 Radar/Laser System
    XPEL Ultimate, Ceramic Pro & Apex Huper Optik window tint
    IG
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Yeah, that sounds more like an issue with the baby, not the car... I found the back seat of the S4 to be really comfortable.
    We got lucky in that our kid does not get sick in the car, but does get PISSED if he is in the car seat too long; he WAILED for the last hour on the trip to/from PA for Christmas.
    Nov 23 2014
    North Carolina
    i'd highly recommend against using any kind of pharmacological intervention for a 10 month old, especially since diphenhydramine is not recommended for children under 2 due to its greater chance of overdose related CNS effects. Dramamine is not recommended under 2 as well, if it is a real issue call your pediatrician and ask for their advice. But like others noted, changing the shocks or suspension will do nothing for the child. it is the overall movement that can make the kid better or worse (worse in your case), so the child needs to either grow out of it, get used to it (through repetition), or be treated for an underlying condition. also note that it might not even be the movement, but the sounds the car transmits, the smell of the interior, or your own driving behavior in general. I wouldn't spend money changing things that will do very little..... or worse, be outgrown by the kid as he ages.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Jul 27 2015
    '14 GWM s4, Suburban, '66 VW convertible, '63 VW single Cab, '68 Caddy Convertible, '64 Vespa
    Allentown PA
    I feel your pain hiwass.
    My wife gets carsick whenever I get a little spirited in my driving or on longer trips with the s4. My kids love it and luckily no throwing up from them in the s4.
    I used to get the same complaint from my wife in my e92 M3 as well.
    The only way I fixed that was to get a Suburban and keep the s4 for myself!
    Coming from e46 and e92 M3's... the S4 is much softer when compared to the M3's.
    As for pre-medicating... please check with your pediatrician 1st. Med's will just hide the symptoms... there could be an underlying problem not yet identified. (Vestibular/Neurologic etc...)
    Good luck and keep us posted.
    Jan 12 2010
    SE Pennsylvania
    Quote Originally Posted by mr shickadance View Post
    I started a thread on "correct tire pressures..." since the psi on the door sticker and in the owner's manual can be very different.
    Look at your owner's manual and use the AUDI recommended psi based on tire size and load.
    For example, on my 2014 S4 with 18" all season tires, with a normal load, the owner's manual has written 36 F and 32 R!!!
    And I drive with a normal load every day. So I keep the psi 36 F and 32 R.
    After my last service, the dealer set them at 44 psi all around!!! Above even the recommended 41 psi for a heavily loaded car.
    Totally wrong...made for a rough ride, reduces grip and would eventually cause uneven tire wear.
    Based on the replies to my post, I suspect Audi is encouraged by the DOT and/or their attorneys to post psi with max load on the door sticker to offer protection in case the driver has a max load.
    Adjusting your tire pressures is an inexpensive way to find out if it will make the ride smoother for your child.
    Good luck.
    Established Member Two Rings Fourcircle's Avatar
    Sep 21 2013
    Athens, Georgia
    I've tried LOTS of different tires and IMHO the tires can and do make a huge difference in the car's ride. Suggest switching to a softer sidewall tire that runs smooth. You'll be surprised how much of a difference in comfort this makes. First pick is Michelin's Pilot Super Sports. They are summer tires and are warrantied to last 30K miles. They run smooth as silk and are very forgiving in terms of harshness. An added bonus is they also handle phenomenally well. I'm running these on my S4 with stock suspension and the car rides as comfortably as my Mercedes E350 did. If it is an all season you want, go with Continental's DWS 06 tire. Is is a plush riding tire warrantied for 45 or 50K miles. Won't run as smooth at speed as the Michelin, but it is very plush. Buy from a shop that gives a 30 day money back or swap out if you don't like. Stick with either of these two and you'll be fine.
    post thought - are you sure one of your rear tires isn't out of round or out of balance that might be giving the little one the upset tummy? A little vibration for 45 minutes would be hard to bear for anyone.
    FourCircle
    Daily Driver:
    2015 S4 Prem Plus, DSG, Daytona Gray on Black Napa, Carbon Fiber Trim, 19s, B and O
    Previous:
    2013 A5 Prestige, Auto, S-line Pkg, Ibis White on Black, Brushed Aluminum trim, 19s, B and O
    Garage:
    2013 Ford Mustang V6, Auto, Pony Pack, Blue on Black
    2012 Ford Focus Titanium, Auto, Gray on Black
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by 4wheelpilot View Post
    Good luck.
    Thanks for the confirmation of my suggestion. It is a solution that can be easily reversed. Try it. IF doesn't improve your issue,put more air back in the tires. Doesn't get any easier.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    All i know is my Bridgestone Potenza RE090 AS become hard as a rock in temps below 40 degrees and anytime i hit a pothole it's a giant thud sound. Its hugely noticeable when the tires are cold and its cold out. When the temps start nearing 60 or above, they become much more livable and comfortable. They have 3 years and about 17k miles on them, not sure if that matters.
    I'll be swapping for DWS 06's in about another month or so. In my experience tires make a huge difference in how the car handles minor bumps and road imperfections. What type of tires OP?
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    May 31 2011
    moore
    Thanks everyone for the suggestions, I'll check with the pediatrician and just wait it out. I take it very easy when the little guy is in the car, no sudden movements and taking my time when switching lanes and turning.
    Jul 08 2010
    tucson
    danbury
    my wife gets car sick, but cracking the window helps her tremendously.
    [CENTER]Scott
    2011 S4
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Toyota Camry?
    Jan 03 2016
    Myrtle Beach, Sc
    35psi all the way around is plenty they are extra load tires. No need for 41-44 psi the dealer pumped them up after i told them not to and i noticed it by just the ride home. Thought i was driving a sherman tank!! lol
