Maybe this is a quick one....
I installed bilstein b8 struts a couple months ago on my h&r OE sports and decided to not install the front bump stops.
I was checking the amount of travel after the suspension was compressed and it didn't look like there was much left.
Day to day drives great, but if I push it through the back roads, where the pavement is pretty harsh, there have been times where I've bottomed out. I've also started noticing wear marks on the inner front fenders from where my tire is rubbing slightly and on the plastic panels below the car. This tells me that the car is going even lower than before, as I never had this issue with oem struts and stock bumpstops.
Is it possible to cut a slit in the bump stop and slide it over the shock tube, so I don't have to remove the whole strut assembly again?
For folks with the same suspension combination, how much did you trim off your bumpstops? 1.2-1.5"? Less? Did you use the top or the bottom part with the dust cover?
Here's a picture on a slanted driveway to show how close it can get (at this point there's probably another 1-1.5" of shock travel, as you might be able to see where it contacts my tire, about halfway on the sidewall).
