    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    B8 AMI Aux Input in Center Console Storage Box
    We don't have iWhatevers, and the 32GB SD card in our Symphony head-unit handles all of my music library for my daily commute when I'm not listening to NPR, so I've been looking for a better way to get aux audio input in our B8. We have AMI in the glovebox, which is nice, but not ideal: audio cables tend to get crimped when they come out of a closed glovebox, so when I found the plug covering the aux input connector hole in the center console storage box (opposite the 12VDC power port) a while back, I set out to determine whether this would work with AMI.
    I found an Aux In connector (8J0-035-475) with the cable for the old(er) RNE head units on eBay from a seller in China for a fair price. I also got a longer 3.5mm stereo extension cable, with the intention of using only the female end to connect to an AMI cable with a 3.5mm plug. After a dry-run with just the cables connected to my streaming audio source & the AMI worked, I fashioned a proper audio extension cable of total length 70 inches (175 cm) using the female end of the stereo extension cable.
    Installation was fun: I haven't had the center console out in this car yet, so I got to figure out that puzzle (without breaking anything), as the cable was to run from the glovebox (out the left side of the AMI box) behind the head-unit & climate control, and out along the right rear air duct, continuing aft under the air duct.
    Apart from getting the console out without breaking too much, the trickiest part was getting the cable up to glovebox: a stiff wire fished from the left side glovebox was used to pull the female cable end up from the console opening. I needed to pull the Symphony head-unit out a bit to help guide the wire out of the glovebox to its proper exit point. I didn't pull the glovebox, but I did have the AMI assembly out to drill a hole for the audio cable end and notch the left rear of the device drawer to allow clearance for the cable to exit the box (and to pull the cable up, of course).
    If I get around to posting pictures anywhere, I'll add them to the thread.
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    Why wouldn't you just get a Tune2Air?
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Aug 31 2014
    NW OH USA
    @doowopaudi: No, cable routed through the center console, terminated in the Aux In socket (8J0-035-475) fitted to the storage box under the front armrest.
    @smellie: I thought about this method, but decided plain-old audio-in a more reliable solution (and less expensive).
    Aug 31 2014
    NW OH USA
    Some pictures of my Audio Aux In retrofit:
    Cables (spliced) and aux-in connector:
    Finished audio extension cable and aux-in connector:
    AMI device box with 9.5mm hole for female cable end:
    AMI device drawer notched for cable clearance:
    Pulling audio cable female end up to glovebox (note that center console, upper air vent, and Symphony head-unit are removed at this point):
    View of "fish" wire behind the Symphony head-unit:
    Audio cable exiting dash under rear vent air duct:
    Audio cable continuing aft:
    Cable run view from rear seat:
    Cable connected to Aux In socket (8J0-035-475) in center console storage box:
    View of audio cable as it clears the front ashtray assembly (to the right):
    Finished audio Aux connector in the center console storage box:
    And no crimped audio cables exiting from under that front armrest:
    For completeness, the finished AMI end in the glovebox:
