Hi all,
It's my first post here. I've been a long time lurker and have to say thanks to those that have contributed to the forum because there is an amazing wealth of knowledge on this site! I'm posting today to see if anyone is able to help diagnose a no-start issue I'm having.
I have recently taken ownership of a pretty special B6 A4 1.8t Quattro Wagon who I bought off the 1st owner after he had moved onto an S5. It's had quite a lot of work done to it and is in amazing condition for its age, the owner is a member of AZ and OzAudi.
Late 2003 Audi A4 S Line 1.8t Quattro 6spd Manual. Non Canbus early model as far as I'm aware.
Mods
I'll list the mods that I feel are relevant for the purpose of this diagnosis:
Stage 3+ APR kit
Garrett GT2860R
APR Front Mount
APR TBE
Porsche Brembo BBK
RNS-E
TTS steering wheel
History
Of recent I've been getting the car going into limp mode due to a 17536 Fuel Trim - System too lean error, as well as 17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High codes. I swapped out PCV & PCR valves (thinking possible vac leak, still need to inspect check valves), as well as rear O2 sensor. I also have a mild boost leak. I had been monitoring my fuel trims and noticed that my long term idle is at around 1.5% yet part throttle had at times risen to ~21%. I also notice a +% spike when coming off throttle sometimes. This lead me to believe it is more a MAF, fuel pump or injector issue rather than a vacuum leak. MAF has just been changed, I inspected it and cleaned yesterday and I don't feel any stuttering that I would expect if the fuel pump was on it's way out.
Problem
I think these issues are separate from my latest and more significant issue. When stepping into the car yesterday, I cranked the car over and couldn't get it to start at all. The car cranks fine, and battery is testing good, but no spark? or no fuel?..
I am getting ABS, ESP and brake light showing on the dash when I try and tick it over. I've made sure it's not the steering wheel lock preventing it kicking over, and I can't see any evidence of it being immobilizer intervening. I'm also hearing the fans cycling over and over when the key is in ignition position. Battery tests ok at 12.5v.
Diagnosing
I ran VCDS and couldn't get a response at all from 01 Engine Controller test. I've checked all fuses and have inspected relays. No obvious signs of failure apart from fan relay 219 in the ECU box showing a bit of corrosion on the contact pads (internal). I tested and the relay still works, although I will order a new one. This would more than likely explain why the fans are going, but they only turn on when key is turned to ignition which is switching the relay.
As mentioned, the battery tested ok, and I tried to kick the engine over with a battery jumpstarter also and still can't get a response. I've unplugged the MAF, both O2 sensors, ABS control unit separately and all together and still can't get a response from the ECU.
Previous owner had passed on the original ECU which I swapped out and tested in the car, still no response from ECU Controller. I've also removed the RNS-E and inspected wiring. The unit was retrofitted into the car but I can't see any obvious wiring issues that might be causing the issue.
I am really hoping I have missed something very obvious.. I would have thought that if it was coilpacks or fuel pump there would be more obvious signs of failure leading up to the issue but it's quite the opposite, the car was running great just prior. Any suggestions are very much welcome, and I really appreciate anyone's input.
VCDS Scan Results
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01(no communication),02,03,08,09,0F,11,15,16,17,18,36,37 ,45,46,55,56,57,65,67,69,75,76,77
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04475
Shop #: WSC 12345
3 Faults Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-00 - -
P1850 - 35-00 - -
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 AC
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
01206 - Signal for Duration of Ignition; OFF
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63251
1 Fault Found:
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655 B
Component: Airbag 8.4EP 3002
Coding: 0010602
Shop #: WSC 63251
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Controller: 8E0 953 549 R
Component: Lenksáulenmodul 1102
Coding: 02042
Shop #: WSC 00000
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 11700
Shop #: WSC 62515
WAUZZZ8E64A125051 AUZ6Z0C0295772
3 Faults Found:
01314 - Engine Control Module
49-00 - No Communications
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01303 - Telephone Transceiver (R36)
Address 37: Navigation Labels: Redir Fail!
Controller: 8E0 035 192 C
Component: RNS-E HIGH EU H50 0650
Coding: 0301115
Shop #: WSC 06335
3 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
004 - No Signal/Communication - Intermittent
01044 - Control Module Incorrectly Coded
000 - -
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 AS
Component: Komfortgerát T01 1210
Coding: 07104
Shop #: WSC 21000
Address 56: Radio Labels: Redir Fail!
Coding: 0301115
Shop #: WSC 06335
3 Faults Found:
011 - Open Circuit
000 - -
End --------------------------------------------------------------------------------------------------
