Results 1 to 21 of 21
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Question on running S7 wheel/tire size on S6
    I just purchased a set of S7 wheels for my S6 and am wondering if any of you have run into rubbing issues. My S6 is lowered, I can include a picture below. The stock specifications on an S6 are 20x8.5 wheels with 43 offset, running 255/35 tires. The S7 wheel comes in 20x9 with 37 offset, running 265/35 tires.
    Would I run into any issues putting on the 20x9 at 37 offset on my S6? Should I go with the 265/35 tire or stretch a little the 255/35 tire?
    Thanks for your help. Here's picture of my S6 lowered
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Feb 11 2013
    C7 S6
    North San Diego
    you'll be fine, plenty of clearance to run a 265, I'm running a 20x9 +25 with minimal rubbing
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    If I understand correctly you are moving the wheel out 6mm and adding 5mm of tread each side. That means 11mm further out from stock. I'm running 15mm spacers with the stock 20" wheel with no problems and some are running 20mm, so you should be fine.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Aug 27 2015
    New Zealand
    I should add that with 15mm spacers and stock 20" wheels, you can drop the car 17mm without any issues.
    Veteran Member Four Rings zee007's Avatar
    Jan 12 2010
    2012 C63; 2017 X5M
    RVA
    FWIW - I ran 20mm front and 25 mm rear spacers on OEM black ops wheels when I had my S6 and it was lowered 17mm. No issues.
    - Zee
    Current: MY22 RS6 | MY19 Q8 | MY74 50
    Past: MY09 TT | MY10 S5 | MY13 AllRoad | MY15 S6 | MY16 RS7 | MY17 911TT | MY17 X5M | MY17 Q7
    Dec 14 2011
    Dublin, OH
    Quote Originally Posted by MadAboutCars View Post
    Yes. Still trying to understand how the offset calculation work. So if I'm reducing the offset number, in this case from 43 to 37, that means I'm pushing the wheel out? That of course with an inch wider tire 255 to 265 would be the 11mm you mentioned.
    Thanks for the input. Just eyeballing it concerned me whether I had enough room.
    Aug 27 2015
    New Zealand
    The tire is 10mm wider (5mm on each side). This also means the diameter of the 265/35 tire is 3.5mm more than the 255/35 tire.
    Dec 14 2011
    Dublin, OH
    Should I put 255/35 tires on the 20x9 wheels or go with 265/35.
    Aug 27 2015
    New Zealand
    If you drive it hard around corners the S6 can benefit from wider tires. I don't know how well the 255's would fit on the 9" wide rim. It's only another 1/4 inch each side. I'll pass to someone that knows more about tire fitment.
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    O.P. I'm so glad you started this thread,i plan on doing the same wheel upgrade on my A6..
    post pics when done please..
    Dec 14 2011
    Dublin, OH
    Will do.
    Prefer not to stretch a 255 tire on the 20x9 wheel. Given the collective feedback above, I'll put 265/35 tires on.
    If anybody's got a set of 265/35 summer tires for sell. Send me a pm.
    Senior Member Three Rings mik34's Avatar
    Feb 04 2010
    Manitowoc, WI
    I run 21x10 HREs with 275 tires and the H&R lowering module on my S6 without a problem. You will be fine.
    Sold: 2013 : Ice Silver, Carbon inlays, APR tuned, 21x10 HRE S101, AWE exhaust, Carbon fiber mirrors from RS6, Drilled rotors, H&R lowering module, Escort 9500ci, Ceramic brake pads, Deval carbon fiber rear diffuser, Xpel Ultimate, Opticoat
    Sold: 2009
    Whoever said money can't buy happiness...doesn't own a (tuned) S6.
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    It's kind of difficult to see in this pic but this is a 255 tire on a 9" wheel, you can see how the sidewall it stretched a bit leaving the lip exposed to curb damage. I'd suggest running the 265/35/20 without a doubt.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by Dguth View Post
    You will be absolutely fine. In fact, I think the 255/35/20 tires for the S6 are undersized for the car. Here is a pic showing fitment of a 265/35/20 tire on a 20x9 wheel with a 35mm offset. 37 mm will be 2mm more inward. The 265 handles better, rides better, and feels like it supports the car better.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Dec 14 2011
    Dublin, OH
    Perfect. Thank you all!
    Established Member Two Rings jagata's Avatar
    Apr 15 2014
    So. Cal
    I need a second opinion of a set of aftermarket rims, 21x10.5 et+32mm I calculated it will be flush to the fenders but maybe I'm wrong what you think? And if I run 275/30/21 will it rub?
    Nov 27 2008
    New Jerz
    Quote Originally Posted by jagata View Post
    http://www.willtheyfit.com/
    Apr 15 2014
    So. Cal
    Thanks for the link, however my problem is I used the above oem rim specs to compare to the aftermarket specs but I do NOT have oem any longer to physically look at to reference with. If any one with oem rims can tell me how far in the oem rims sit back to the fenders it would be greatly appreciated.
    Veteran Member Three Rings Demandred's Avatar
    Jul 25 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    I was told that a 10.5 rim would stick out past the fenders on a S6 - especially on the rear where it is not as pronoucned in the flaring
    and guess running the 265/35 it will run slower than the speedo reports - but only 1% so not tht much of an issue?
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
    Nov 19 2005
    Central IL
    There is no way in hell those will be even close to fitting. You'd have to be in the mid 40's offset to get a 10.5" wheel to be tucked in the wheel well.
    Apr 15 2014
    So. Cal
    Thanks I had a feeling I was off, so +45mm sounds right for a 10.5 wide rim?
