    Veteran Member Four Rings lunamarA4's Avatar
    Feb 26 2004
    lots of tools and spare parts
    San Diego, CA
    CCM swap from late b7 into a 2004 B4
    How hard is it to swap a B7 comfort control module into an 2003 and older B6?
    Some stated you need to rewire the connectors as the two CCMs are different or does this only apply of the 2002 B6's?
    Or is this more of a plug and play for the late B6's
    What advantages does going with B7 CCM have for us B6 guys?...I read so far...reprogramming the wipers to adjust to speed and eliminating the extra swipe after spraying the windshield
    Anything else?
    Does it help with the Steering wheel conversion to the B7/B8 model also?
    Thank
    4 SALE B6/B7 parts
    RafE |2004 BT White A4 Avant|
    |2002 S8 6spd - fully overhauled + 6 spd|
    |1988 E30 S52 Pandem Kit|
    |1991 E30 M20 Touring|
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    I'm searching for the answer exactly too this right now. Did you ever figure out?
    Dose b7 ccm have longer range too?
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    Don't have all the answers for you but later b6 it's more plug and play. Retrofit for the earlier. I believe the ignition is related to it with the key fob and those other setting will be done with a Ross tech but I am not sure what all it allows.
    What ever makes sense go with the opposite and you got it
    Nov 03 2012
    California/so cal
    Quote Originally Posted by Biged243 View Post
    I see I saw something somewhere else saying there's something different with the windshield wipers not doing one extra wipe or something like that. I'm just More curious with the range and compatibility. From everything else I've seen in threads the:
    8E0 959 433 BT module (b7)
    Should work fine i plan on using the b7 fob.
    But I have a few from b6 as well
    The 8E0 959 433 BB
    Deferent years too
    2002
    2003
    2004
    BT version is 2005
    But if one offers more range I would like to use that one. At this point I don't know if the range is even dependent on the module as much as the fob and antenna although.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Mar 27 2013
    Vr6 gti
    Maybe true for the wipers, I think I saw that too somewhere. With the range, when I had my b7 the range sucked too. Even with new batteries. Others on the b7 forum have complained about it too. I don't fully recall but something about the shark fin? I don't really remember what they speculated but the range wasn't great for me.
